Results 1 to 16 of 16
Thread: Pushrod length
    Member Goldcuffs's Avatar
    Aug 2008
    Florida
    2000 Trans Am
    Pushrod length
    I'm using a TSP 224R. I'm pretty sure I need 7.400 pushrods but not positive. Can someone confirm?
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    Yea, 7.4 should be right. Doesnt hurt to check though.
    What heads?
    What lifters?
    What rockers?
    No matter what....CHECK!
    Lowered, HID's, tinted.
    Aug 2008
    Florida
    2000 Trans Am
    What heads?
    What lifters?
    What rockers?
    Stock heads, stock lifters, stock rockers.
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    You can buy a pushrod length checker for a couple of bucks at a parts store.
    Lost in Texas
    Custom Slate Blue
    99 B4C
    It's best to check,I have seen them range from 7.375 to 7.425 on even stock setups. 7.400 will function, but pushrods not being perfect really contributes to what is so well known as the LS1 sewing machine sound
    Florida
    1999 TA WS.6
    The base circle of that cam shaft should be stock size. But a pushrod length checker is so cheap, it would be foolish not to check real quick.
    mercersburg pa
    hugger orange
    2004
    Quote Originally Posted by JaycenK View Post
    I just got one from Summit Racing for $11.99....its worth it
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    i would be surprised if it wasn't to tell you the truth
    Most aftermarket cams (a few years ago anyways) had a slightly smaller base circle than stock, so you wanted a 7.425" pushrod instead of the stock length.
    This is why you ALWAYS check.
    NC
    SOM
    1998 T.A.
    I measured my stockers when they came out and they were 7.385......
    Lost in Texas
    Custom Slate Blue
    99 B4C
    Technically the stockers are 7.325, they aren't measured in actual tip to tip length.
    LS7 lifters sit taller because of the internals too, so they require shorter ones than if you don't change the lifters. I just put stock height L92 heads on an LS2 with stock gaskets and LS7 lifters and it needed 7.375. Virtually stock valvetrain noise, not the "typical" sewing machine sound at all.
    mercersburg pa
    hugger orange
    2004
    Quote Originally Posted by oneBADDz View Post
    makes me wonder what size pushrods i'll need with milled heads and ls7 lifters.
    I have the pushrod checker sitting on the table. just screw/unscrew to the right lenght, then measure tip to tip for the lenght I take it?
    Aug 2008
    Florida
    2000 Trans Am
    Is there a gauge or a read out of some kind on the length checker or do I need to buy something to measure the length checker? Also when I measure I want the rocker to ride as close to the center of the stem as possible, correct?
    I have one.
    Kinda a pain in the ass to use, but it is worth its weight in gold.
    You want to make sure it is right.
    I have 7.325" pushrods in my motor. Stock style heads milled .020", TSP LS1 cam, Morel/Lunati lifters, cometic .045" head gaskets.
    There are so many variables, just check it.
    http://www.hardcorels1.com/vbulletin...read.php?t=622
    Aug 2008
    Florida
    2000 Trans Am
    I have one.
    Will do, Thanks.
  1. pushrod length?
    By Edward-T in forum Internal Engine
    Last Post: 10-21-2011, 05:36 AM
  2. pushrod length??
    By Mikat1 in forum Internal Engine
    Last Post: 03-15-2011, 10:36 AM
  3. need help with pushrod length
    By SexyTransAm in forum Classic Muscle
    Last Post: 01-15-2008, 04:50 PM
  4. Pushrod Length?
    By Pickupman404 in forum Internal Engine
    Last Post: 03-02-2007, 06:43 PM
  5. pushrod length help
    By laststaric in forum Internal Engine
    Last Post: 07-19-2006, 06:26 PM
