Results 1 to 3 of 3
    Trans Am for life baby SexyTransAm's Avatar
    Feb 2007
    E-town, Kentucky
    95-black & 80-blue
    95 Trans Am and 80 TA
    need help with pushrod length
    ok i have no clue what length pushrods to get. idk if stock length will work, and hell what is stock length?
    my cam is .525 on both sides, and i have 1.6 rocker rollers, hydraulic flat tappet lifters. it goin in a 80 motor, for my 80 rebuild. so any hepl would be great.
    95 TA A4, Black on Black C5 Z06 wheels, CAI, 160 powerstat, TB coolent bypass, TB foil, LT4 Knock Sensor, STB, SFC, Poly trans and torque arm mounts, flowmaster muffler, gutted cat, and hypertech tuned.
    http://www.fquick.com/SexyTransAm
    Feb 2007
    E-town, Kentucky
    95-black & 80-blue
    ok i have now been told that stock is 7.794. and 7.800 will also work. will that work with my set up?
    ga
    blue
    1998 trans am
    IS IT A pONTAIC ENGINE OR A cHEVY ENGINE?
    put one of your stock ones in and check the rocker arm to valve tip contact pattern, and go from there. You can also buy an adjustable rod to change the length until its right, then special oerder the length rods needed.
  1. pushrod length?
    By Edward-T in forum Internal Engine
    Last Post: 10-21-2011, 04:36 AM
  2. pushrod length??
    By Mikat1 in forum Internal Engine
    Last Post: 03-15-2011, 09:36 AM
  3. Pushrod length
    By Naf in forum Internal Engine
    Last Post: 07-28-2007, 05:06 AM
  4. Pushrod Length?
    By Pickupman404 in forum Internal Engine
    Last Post: 03-02-2007, 05:43 PM
  5. pushrod length help
    By laststaric in forum Internal Engine
    Last Post: 07-19-2006, 05:26 PM
