Results 1 to 2 of 2
Thread: pushrod length help
07-15-2006, 08:35 AM #1Junior Member
- Jul 2006
- Missouri
pewter- 2001 z28
pushrod length help
I am wondering if anyone has about the same setup and what length pushrod they used. I have an 2003 ls1 engine in a camaro z28. I have a 5 angle valve job done and the heads have been milled .020. Stock cam shaft. I do plan on using the slp 1.85 ratio rockers. I know the stock rods are 7.4. I do have a rod checker and cant really decide on the best length. 7.35 looks good but then 7.325 and or 7.375 doenst look bad either. There really isnt a big pattern difference on the valve stem. It doesnt make a pretty line in the center. It does however wipe a large area more or less in the center of the valve stem. I am using blue marking dye. I was hoping someone out there had about the same setup. Any help woud be appreciated. Thanks.
07-19-2006, 05:26 PM #2
in theory, the heads are cut .020". so, 7.400 - 0.020" = 7.380"
pushrod length?
By Edward-T in forum Internal EngineReplies: 8Last Post: 10-21-2011, 04:36 AM -
pushrod length??
By Mikat1 in forum Internal EngineReplies: 1Last Post: 03-15-2011, 09:36 AM -
need help with pushrod length
By SexyTransAm in forum Classic MuscleReplies: 2Last Post: 01-15-2008, 03:50 PM -
Pushrod length
By Naf in forum Internal EngineReplies: 2Last Post: 07-28-2007, 05:06 AM -
Pushrod Length?
By Pickupman404 in forum Internal EngineReplies: 21Last Post: 03-02-2007, 05:43 PM
