Thread: ticking rockers
11-17-2009, 06:46 PM #1Junior Member
- Nov 2009
- texas
red- 2000 camaro
ticking rockers
I've got a ticking noise coming from the valve covers and was told it was the lifters(or a lifter). I know the heads have to come off and was wondering if someone could tell me if it's easier to drop the engine or just do it in the car?
Any advice would be appreciated.
11-17-2009, 07:16 PM #2Just me
- Nov 2006
- Broken Arrow, OK
You can pull the heads without dropping the motor, so it can be done. It would probably be easier to work on if you pulled the motor, but just depends on what you prefer doing.
11-18-2009, 06:40 AM #3Awaiting Activation
- Oct 2007
- NC
SOM- 1998 T.A.
Before you pull the heads I would check the easy stuff first. Pushrods, loose rockers and puked needle bearings in the rockers.....
11-18-2009, 10:30 AM #4
yes definately check for bent pushrods and loose rockers before ripping the heads off. If you don't find anything up top, what kind of lifters are you gonna run?
11-18-2009, 06:33 PM #5Junior Member
- Nov 2009
- texas
red- 2000 camaro
Rockers are new, but havnt checkd pushrods, thinkin about a cam swap. Any recomendation on brand, lift, duration. Would like to keep the stock rockers and valve springs.
11-18-2009, 09:52 PM #6
12-09-2009, 03:58 PM #7Junior Member
- Mar 2007
- Charlotte, NC
Yellow- 2002 Trans AM
if you use the stock springs with the new cam, you will smash the springs and break them. This will drop the valve and cause bigger problems.
With any cam swap that you might want to do, you will be using more lift and that will compress the spring more. You need to be careful with this or severely damage the motor
12-09-2009, 04:50 PM #8
bad ticking
By Firebirdformula99 in forum Internal EngineReplies: 11Last Post: 04-23-2012, 05:51 PM -
Help: ticking??
By nativetalon in forum External EngineReplies: 3Last Post: 02-18-2011, 07:09 AM -
ticking
By barryTA in forum External EngineReplies: 3Last Post: 01-17-2007, 09:26 AM -
ticking
By stangereater in forum Internal EngineReplies: 14Last Post: 09-23-2006, 08:14 PM -
ticking
By daas5 in forum Almost Anything GoesReplies: 7Last Post: 04-06-2006, 10:58 AM
