Thread: pushrod length
11-12-2009, 04:25 PM #1Junior Member
- Oct 2009
- perth australia
black- commodore 2000 maf tuned
pushrod length
hi everyone just after a quick answer.I have a texas-speed 228R camshaft and was wondering would my 7.425'' pushrods be the right length or should i have got the 7.450'' length pushrods.Is it true that texas-speed cams are ground with a reduced base circle ie 50thou(mm) if that is the case should i have got the 7.450'' std 7.40''+50thou=7.450" any help would be welcomed.cheers
11-12-2009, 04:33 PM #2
I just got stock length rods ( 7.400) for my f-body running that cam. You really should measure for them in all honesty.
11-12-2009, 09:28 PM #3
you can get an adjustable pushrod to check to be sure what length you need. you should beable to pick one up for around $20 at a local speed shop or summit racing
11-12-2009, 09:40 PM #4
Measure to be sure. 20 bucks.
pushrod length?
By Edward-T in forum Internal EngineReplies: 8Last Post: 10-21-2011, 04:36 AM -
pushrod length??
By Mikat1 in forum Internal EngineReplies: 1Last Post: 03-15-2011, 09:36 AM -
need help with pushrod length
By SexyTransAm in forum Classic MuscleReplies: 2Last Post: 01-15-2008, 03:50 PM -
Pushrod Length?
By Pickupman404 in forum Internal EngineReplies: 21Last Post: 03-02-2007, 05:43 PM -
pushrod length help
By laststaric in forum Internal EngineReplies: 1Last Post: 07-19-2006, 05:26 PM
