Results 1 to 2 of 2
09-20-2009, 01:53 PM #1Junior Member
- Aug 2009
- south carolina
noise from the front of the motor
when my car is at idle i can hear like a grinding noise seems like its from around the water pump area it dont make it all the time have any of you ever had this happen to your cars please help figure out kinda where its coming from thanks to everyyone who has helped me with things on here.......
09-20-2009, 09:34 PM #2
probably one of the idler pulleys. Pull the belts and verify no noise, then put the AC belt on and check again. If it returns its the AC idler or tensioner. If not check the other pulleys for smooth operation when you turn them.
Front end noise
By pajeff02 in forum GM TrucksReplies: 19Last Post: 10-27-2010, 07:19 AM -
Noise from the front
By 1972_Z-28 in forum Suspension and HandlingReplies: 4Last Post: 02-23-2009, 06:02 AM -
Window motor noise
By GULLETT17 in forum Stereo and ElectronicsReplies: 0Last Post: 11-19-2008, 09:02 AM -
Bad noise from motor.
By drummer52910 in forum General HelpReplies: 0Last Post: 12-18-2007, 06:26 PM -
noise in my motor, help
By nabdrill in forum Internal EngineReplies: 13Last Post: 06-05-2006, 10:46 AM
