Results 1 to 20 of 20
Thread: Front end noise
10-25-2010, 06:15 PM #1
Front end noise
We picked up an '07 Suburban in late August and have put around 1,000 miles on it. This evening, Dawn went to head over to her son's with a load of furniture and called me from 5 minutes down the road saying that the truck was making some noise. I had her turn around and come home so I could take it for a spin.
Sure enough, there is an intermittant grinding noise that is very loud coming from the left front wheel. It seems unrelated to the brakes and will do it both while turning and going straight. Seems much to sudden for a wheel bearing as the truck didn't make any noise when I drove it 40 miles yesterday. I looked under it quick and do not see anything awry. The CV joint boot is intact and no grease is being thrown.
Any ideas? It's raining good up here so I am waiting until tomorrow to get it up in the air to check things out.
10-25-2010, 09:33 PM #2
10-26-2010, 04:52 AM #3
10-26-2010, 08:14 AM #4
When you're driving at slower speeds (parking lot), make hard turns both ways. If the noise gets louder when you're turning right and quiets when you turn left, it's probably the wheel bearing. Good news is, if that's what it is, it's covered under the powertrain warranty. If you have it in the air, rock the tire top to bottom to see if there is any play in the bearing. We change wheel bearings all the time, mileage really doesn't come into effect as much as road conditions do.
2018 Tahoe - Silver - OEM
10-26-2010, 10:10 AM #5
10-26-2010, 11:03 AM #6
i would check to be sure like konig said . did you have a load of furniture in it yesterday though?
10-26-2010, 11:38 AM #7
10-26-2010, 12:40 PM #8
They go either way. You can have a small noise gradually grow, or you can have play in the bearing with no noise at all. We have seen it several ways. Go out and drive it and load up each side, that will be a sure sign. That or wobble the tire top to bottom when you have it in the air. But keep in mind, sometimes it will grind but have no play what so ever, and vice versa, it will have tons of play but it will be quiet. Those bearings are a little squirly sometimes.
10-26-2010, 12:44 PM #9
10-26-2010, 01:23 PM #10
in the diff there is bearings that could go bad also.
10-26-2010, 03:50 PM #11
Yes, but unless the boot is torn, we don't see many CV's going bad. And nothing at the end of the axle, I assume you mean towards the wheel not the differential. Just the CV to the hub.
Yes true, but it is not common at all. Easiest way to tell is, diff bearing noise won't change pitch on side to side driving motions and the noise usually will "pulsate" when cruising at a constant speed.
10-26-2010, 03:54 PM #12
I've had bearings go out and not be pulsating and i know about the side to side . just throwing out any possibilities .
10-26-2010, 03:58 PM #13
10-26-2010, 04:49 PM #14
10-26-2010, 04:50 PM #15
10-26-2010, 04:51 PM #16
10-26-2010, 05:01 PM #17
10-26-2010, 05:57 PM #18
10-27-2010, 08:16 AM #19
Heading up to the dealership after lunch to get the bearing replaced. I have my brother-in-law on standby in the roll back just in case I don't make it.
10-27-2010, 08:19 AM #20
you should be ok to drive but good idea to have a backup . good luck.
Front end noise
By homickb in forum Suspension and HandlingReplies: 30Last Post: 07-06-2012, 06:13 PM -
noise from the front of the motor
By cheeseburger in forum General HelpReplies: 1Last Post: 09-20-2009, 10:34 PM -
Noise from the front
By 1972_Z-28 in forum Suspension and HandlingReplies: 4Last Post: 02-23-2009, 07:02 AM -
front end noise
By rsg98Z28 in forum General HelpReplies: 1Last Post: 11-13-2008, 10:35 PM -
Bad noise from front of engine
By camarokiddave in forum General HelpReplies: 7Last Post: 02-14-2007, 12:37 PM
