Results 1 to 14 of 14
    Junior Member nabdrill's Avatar
    Northeast Louisiana
    Hugger Orange
    98 Camaro
    noise in my motor, help
    Got a pecking noise coming out of the driver's side of my motor.
    It came on today pretty loud and then went away, it lasted for a couple of minutes. Happened twice. I know its the motor cause it changes speed with rpm.
    Is this lifter noise, valvetrain.... any opinions appeciated
    Member Huskerz1's Avatar
    99 SS Vert M6
    Did you happen to see where your oil pressure was at during this noise?
    Awaiting Activation Liquifire's Avatar
    central wisconsin
    header leak if not directly from the motor?
    Northeast Louisiana
    Hugger Orange
    98 Camaro
    The oil pressure was normal, no flux. there at all.
    This is a 120K motor.
    central wisconsin
    does it do it warm and cold...........if you throttle it under the hood, it does follow the RPM's, right?
    Northeast Louisiana
    Hugger Orange
    98 Camaro
    yes, it changes with rpm's
    DFW
    1999 SS
    drain your oil and see if there are any needle bearing stuck on your drain plug. I have had 2 broken rocker arms in the past month. Made a hell of a noise. Thought it was a lifter, but pulled the valve covers and there were the pieces of the rocker arms! Just upgraded to the Yella Terra rockers, no probs so far.
    Memphis, TN
    2002 Z28
    Miss any shifts lately? Could be a bent pushrod.
    TimeslipRegistry.com
    Timeslip database and racing videos
    central wisconsin
    I hate to say it but the best way to find out is to rip the valve covers off to find out for sure or atleast eliminate a lot of options
    Artic White
    99 SS
    Quote Originally Posted by Liquifire
    Pulling off the valve covers insn't that bad *after* the first time you do it. Pull em off and check the valve train. If you find the problem there, fix it. If the problem isn't in the valve train, well at least you gained some experience and aren't as intimidated about getting into your engine as you were before. Happened to me . Best of luck to ya
    Northeast Louisiana
    Hugger Orange
    98 Camaro
    Can the intake and heads be removed without pulling the mtr?
    Pueblo, Colorado
    1998 Pontiac Trans Am
    Quote Originally Posted by nabdrill
    Yep. http://www.ls1howto.com/index.php?article=3 and http://www.ls1howto.com/index.php?article=5
    Its got an awesome write-up for both.
    Northeast Louisiana
    Hugger Orange
    98 Camaro
    Holy #@$%!!
    That howto website is too good to be true.
    A do-it-yourselfer's dream...
    02 ws6 timmyvws6's Avatar
    Grandville MI.
    2002 Transam ws6
    Had the same noise in my 02 ws6. took it to the dealer and everyone in the shop said the same thing. Piston slap. I was told that they see this a lot with this motor. they ordered a set of eight high tolerance pistons to replace the under size ones in my motor. The whole rebuild cost me $100.00. Thank God I had one year left on my bumper to bumper. The car had only 11,200 miles on it. It's all good now.
  1. noise from the front of the motor
    By cheeseburger in forum General Help
    Last Post: 09-20-2009, 09:34 PM
  2. Window motor noise
    By GULLETT17 in forum Stereo and Electronics
    Last Post: 11-19-2008, 09:02 AM
  3. Bad noise from motor.
    By drummer52910 in forum General Help
    Last Post: 12-18-2007, 06:26 PM
  4. Antenna motor making noise
    By indiana hawk in forum General Help
    Last Post: 06-10-2006, 10:04 AM
  5. ac/heat blower motor making noise
    By sg5492 in forum General Help
    Last Post: 02-12-2006, 04:25 PM
