Results 1 to 11 of 11
Thread: Burnout
    Aug 2009
    NJ
    Blue
    02 Trans Am WS6
    Burnout
    I was trying to do a burnout and the first time wheels started spinning then stopped and the car was gunnna turn off. Second attempt didnt get that far just went straight to turning off smoke came out but it wasnt the tires it was clutch. Third attempt wheels spun then car started turnin off. Heres how i did it i pushed the clutch in got it to 4 rpm then dumped it and held the break and tried getting the rpm up to five and kept turning off on me with the tcs off. Did i do something wrong. Oh and i have to jam it to get it into any gear. Doesnt wanna go into reverse at all unless i use force. How bad is the damages and if i let it sit for a lil will it go back to normal until i can find a clutch?
    Carless blkSS98's Avatar
    Jan 2008
    Eastsound, WA
    WOW!
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    Oh boy....
    🤔 11s. blackbirdbrain89's Avatar
    hagerstown, mercersburg
    black trans am
    2000
    humm... u probly need ur trans rebuilt and deff a new clutch... stage 3s are nice and streetable as well...
    Aug 2009
    NJ
    Blue
    02 Trans Am WS6
    Who makes the stage 3?
    Junior Member jeffz0rz's Avatar
    Sep 2009
    san diego
    2003 gmc sierra
    "and sometimes when it wont go into 1st gear, i kick the shifter rally hard 3 or 4 times, then its good. is this normal? "
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Quote Originally Posted by animal323 View Post
    Spec.
    Didn't you post this same thread already in a different section?
    Quote Originally Posted by jeffz0rz View Post
    Your shifter should always go into gear when you have your clutch disengaged. If it doesn't, something is wrong. Bad synchro, bad throw out bearing, bent shift fork?
    You were 'burning out' with the clutch and you tried again????????????????
    First problem....you killed your clutch.
    Second problem....you pushed the brake down WAY too hard for the burnout.
    Luckily...I doubt you damaged the transmission. I could be wrong, but I am willing to bet you smoked your clutch badly enough to create the new found issues.
    My recommendation???
    Get a new clutch (LS7 kit comes to mind). Don't try anymore burnouts.
    Lowered, HID's, tinted.
    Pittsburgh
    2008 Hummer H3
    All I can say is WOW! Learn how to use three peddles @ once for much better results.
    Member Ramair1's Avatar
    Hugo, OK
    Black/PurpleChromeFlames
    1999 Pontiac Trans Am WS6
    And when you do get a new clutch, do you're burn out in 2nd gear. You may want to invest in a line lock if you plan to continue racing as well. Also turn your mirrors down to watch how your tires are heating up.
  1. Help: Can't do a burnout!!!!!
    By Maro_Man in forum Camaro / SS
    Last Post: 03-31-2010, 06:56 PM
  2. Burnout
    By animal323 in forum General Help
    Last Post: 09-09-2009, 07:38 PM
  3. How NOT to do a burnout....
    By Z28_06374 in forum Multimedia Section
    Last Post: 08-06-2008, 10:07 AM
  4. WS6 A4 burnout?
    By slikws6 in forum Firebird / WS6
    Last Post: 07-15-2008, 01:32 AM
  5. Burnout ?
    By LS177 in forum General Help
    Last Post: 05-05-2007, 07:35 PM
