Results 1 to 20 of 20
Thread: Burnout
    Aug 2009
    NJ
    Blue
    02 Trans Am WS6
    Burnout
    I was trying to do a burnout and the first time wheels started spinning then stopped and the car was gunnna turn off. Second attempt didnt get that far just went straight to turning off smoke came out but it wasnt the tires it was clutch. Third attempt wheels spun then car started turnin off. Heres how i did it i pushed the clutch in got it to 4 rpm then dumped it and held the break and tried getting the rpm up to five and kept turning off on me with the tcs off. Did i do something wrong. Oh and i have to jam it to get it into any gear. Doesnt wanna go into reverse at all unless i use force. How bad is the damages and if i let it sit for a lil will it go back to normal until i can find a clutch?
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    If you have a bad rear main seal, you prob seized the clutch to the pressure plate or flywheel. That would explain the gear selection difficulty. You need a new clutch ASAP. Clutch was probably on the outs before ya did the burnout.
    Aug 2009
    NJ
    Blue
    02 Trans Am WS6
    I was in second gear the whole time by the way. I think the clutch was already bad i had problems with it b4. It would pop out of second gear sometimes did it a few times in third. Its rough shifting as is. Now i think i completly destroyed it. Could it be anything else besides the clutch?
    North Jersey
    2004 GTO M6
    Your syncros may be bad. If so, then you will need another clutch and a trans rebuild/replacement...=$$$$
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    If you are having it stick in a gear or finding it hard to get into a gear, that is normally a broken synchronizer key in the transmission.
    That's not cheap! Consists of pulling the transmission and rebuilding like the above said. OEM keys are stamped hollow metal. Aftermarket keys are solid.
    Junior Member jaydean21849's Avatar
    Jun 2009
    brownwood texas
    1998 ta
    why would u have to dump it at 4000 ur car has plenty of power to start a burnout at lower rpms i had a 96 z71 i could do burnouts on at lower rpm and it had 35-12.50s on it
    Member TA98's Avatar
    Mar 2009
    Maryland
    Syncros
    Quote Originally Posted by jaydean21849 View Post
    Maybe he wanted to replace the stock 10 bolt also?
    Jun 2009
    brownwood texas
    1998 ta
    good way to get wife to let u do mods tell her it just broke lol
    Aug 2009
    NJ
    Blue
    02 Trans Am WS6
    Honestly its not the first time i heard syncros ive heard that twice before when i mentioned the grinding and i was told they tend to be weak on the ws6. I dump it at 4 cause thats what i taught myself at. I noticed if i take traction off rev it to 3 dump it it spins the tires hit the brakes real quick with my foot still on the gas the car starts to turn off but if i go at 4 it stays on. Is there a reason for that? Thats true about the modding i dont have a wife but i have a girl who wont stop telling me stop spending money on the car.
    Aug 2009
    NJ
    Blue
    02 Trans Am WS6
    Oh how much am i lookin at price wise for the syncros?
    Quote Originally Posted by animal323 View Post
    Sounds like time for a clutch, trans rebuild... and a new g/f!
    Veteran Blackbird WS6's Avatar
    van down by the river
    BTW- when your geting a new clutch and trans rebuilt get yourself a linelock will help alot lol
    Well, that depends. Are you doing it yourself or paying someone to do it?
    If you are just buying the parts and know what you are doing, it will not be that expensive. If you are pulling the transmission, I would recommend upgrading some of the other components in there that tend to be weak also, such as your 3-4 shift fork that is aluminum. Get a steel one.
    I had mine totally rebuilt by RPM transmission. Their costs are listed on their website; level IV and level V upgrades.
    There are also other well-known reputable places to have the work done. Just for a transmission pull and re-install you could be looking at several hundred not including parts or install of parts.
    Quote Originally Posted by Blackbird-WS6 View Post
    Totally agree on this.
    Aug 2009
    NJ
    Blue
    02 Trans Am WS6
    I dont have that type of money rite now. Thats why im trying to get a ballpark figure. Im going to be bringing it to someone to get it done.
    TEXAS... U mad?
    Black / Stryker Blue
    2K WS.6/ 2K9 G8GT
    You should also be in 1st.... You're bogging it, thats why its shutting down on you.
    Keys are $60.
    http://www.thegearbox.org/catalog/it...17/3508384.htm
    A new fork would be an additional $50.
    http://www.thegearbox.org/catalog/it...17/3508326.htm
    I would do that since you'll already have the trans pulled. It's the next weakest link in the T56.
    Call a transmission shop and ask how much to replace them??
    Single Malt rbob93's Avatar
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    If you're short on cash, quit doing 4K dumps or you will be replacing your rearend soon.
    They are weak.
    Good Luck
    Aug 2009
    NJ
    Blue
    02 Trans Am WS6
    Thanks for the info SS and i will call a few shops. Bob i no the rearend is weak but throughout the time i owned the car i only attempted 4 burnouts and three were on the same day but it didnt catch not gunna try again until i get a new clutch ill dump at 3 next time.
  1. anybody sen diz burnout b4??lol
    By 98maro in forum Multimedia Section
    Last Post: 05-15-2010, 02:29 AM
  2. Help: Can't do a burnout!!!!!
    By Maro_Man in forum Camaro / SS
    Last Post: 03-31-2010, 06:56 PM
  3. How NOT to do a burnout....
    By Z28_06374 in forum Multimedia Section
    Last Post: 08-06-2008, 10:07 AM
  4. WS6 A4 burnout?
    By slikws6 in forum Firebird / WS6
    Last Post: 07-15-2008, 01:32 AM
  5. Burnout ?
    By LS177 in forum General Help
    Last Post: 05-05-2007, 07:35 PM
