Thread: Burnout ?
    Phoenix
    1998 z28 ls1
    Burnout ?
    When I press the brake and give my car some gas only one wheel spins. Is there something wrong with my Diff?
    Senior Member bills98ta's Avatar
    Feb 2007
    St Thomas, PA
    If it is still a posi unit, the clutches could be shot, or it has the slip additive thats over working... Maybe pull the cover and if every thing looks normal, try new gear oil...If that happens at the track, get the one tire hot / STOP / burn out again and the other wet tire will now spin !!!
    old timer blue02Z's Avatar
    2002 Z28
    yeah, do a diff service and clean out your rearend. check that magnet on your cover
    San Diego
    2002 T/A
    Not to sound condescending, but how do you know only one tire spins? Marks on ground, someone told you, vehicle pulls a little to one side? Some people mistake the latter for only one tire spinning. My .02
    d
    2002 z28
    i think the rpo code to know if you have posi tac is G80. correct me if im wrong. if you ahve that code on the drivers side of the door and both arnt spinning then somethings wrong
    Junior Member chuckstop00's Avatar
    Milford, MA
    2000 Firebird Formula
    Traction control? I only ever really did 1 burnout in my car (see avatar)
    It was at a car show in Worcester Ma., where they have a burnout exhibition.
    I got some old dunlop tires and aluminum rims so wouldn't hurt the good stuff.
    I tried to start in 2nd, and the "experts" came over and told me to turn the
    traction control off. Well, I don't have it, so dropping back to 1st, and feeling
    the catch point, I was able to get it done! Lasted about 2 minutes before
    they said my time was up. The dunlops wouldnt blow! I have a video of it too,
    if someone knows somewhere I can upload it, be glad to share it. BTW I am
    new here, but have trolled these forums for years. Excellent stuff, have mods
    that I found here.
    2000 Formula - 6spd & t-tops
    300,000 + smiles
    Member SSpdDmon's Avatar
    Farmington, MI
    SOM
    '01 Camaro SS
    I don't know about every year, but the '99, '02, and '01 I have owned all had Zexel diffs. Unless there was little resistance (like when you're in the waterbox at the strip), the diff wouldn't lock up unless you hammered the tires loose. If you just rolled into it, the back right tire would be the only one spinning. The same would be true while going through the corners. I could always get the car to 'step out' around a left hand turn because the back right tire was on the outside. But during a right hand turn, the car wouldn't 'step out' unless I really got into it hard and fast....and if the turn was sharp enough, I could do a one-wheel-peel around the corner. It has to do with the Zexel's design. Search on Yahoo! and you're bound to find something more in-depth to explain.
    Now, there was an option for an Auburn posi. But, I believe that was upwards of $800 and may have only been available on the SS/WS6 cars.
    the chief oldguy's Avatar
    SC
    1998 TA Convertible
    Cool
    Make sure it is a posi, look for G80 in codes.
    Even if it shows up in the codes, the rear end may have been changed out unless you know the previous owners/history of the car.
    Milford, MA
    Found a clearer pic for my avatar.
    Also found a link that someone did for me in a previous "life"
  1. anybody sen diz burnout b4??lol
    By 98maro in forum Multimedia Section
    Last Post: 05-15-2010, 02:29 AM
  2. Help: Can't do a burnout!!!!!
    By Maro_Man in forum Camaro / SS
    Last Post: 03-31-2010, 06:56 PM
  3. Burnout
    By animal323 in forum General Help
    Last Post: 09-09-2009, 07:38 PM
  4. How NOT to do a burnout....
    By Z28_06374 in forum Multimedia Section
    Last Post: 08-06-2008, 10:07 AM
  5. WS6 A4 burnout?
    By slikws6 in forum Firebird / WS6
    Last Post: 07-15-2008, 01:32 AM
