Thread: Throttle Body heater/vent hoses?
09-06-2009, 05:23 PM #1Junior Member
- Aug 2006
- Toronto, Canada
Black- 1999 Firehawk TA Conv.
Hi folks,
Looking for some comments. I had a head/cam job done a few years ago at a local performance shop and didn't notice until today while removing and cleaning the throttle body that they removed the heater outlet hose and vapor vent hose and joined the two.....so bypassing the throttle body all together. So the hose from the rad goes direct to the vapor vent tube, leaving the two hose connections at the throttle body open.
Did they do this to possibly keep the throttle body cooler or what? Un-connected and open inlet openings on the throttle body don't seem right to me.
Do you guys think this is OK or should I re-install the hoses in the right places?
I would ask the speed shop but they have gone out of business with the bad economy :-(
Thanks!!
09-06-2009, 06:32 PM #2
That heating is to keep the throttle body from freezing in very cold temps. They actually sell the bypass for ridiculous prices. If you're not concerned about cold temps, leave it - consider it an added performance upgrade.
09-06-2009, 06:36 PM #3
I see you are from a little further north than most of us. DaddySS said it right though, unless you drive your car in cold damp weather the bypass should not pose a problem.
09-06-2009, 07:08 PM #4Junior Member
- Aug 2006
- Toronto, Canada
Thanks for the replies guys!
Being a convertible, I only drive it in warmer, sunny weather, so doubt I need it then.....just seems weird to see those two inlets on the throttle body open.
Is this really a performance upgrade then?
09-07-2009, 04:29 AM #5
09-08-2009, 10:10 AM #6Member
- tx
pewter- 99 trans am ws6
i would cap the throttle body inlets
dont want a heater, heater hoses
By tomcamaro97 in forum External EngineReplies: 2Last Post: 05-22-2014, 06:17 PM -
heater core hoses
By v6camaro in forum V6Replies: 6Last Post: 02-26-2011, 07:54 PM -
58mm BBK throttle body hoses problem, please help
By steiger99 in forum LT1Replies: 2Last Post: 07-18-2009, 07:50 PM -
Heater hoses where can I buy them?
By carnutt in forum External EngineReplies: 5Last Post: 07-14-2009, 10:05 AM -
Heater core inlet/outlet hoses
By 01SS in forum Parts Wanted / TradeReplies: 1Last Post: 05-22-2009, 10:36 AM
