Thread: heater core hoses
02-22-2011, 06:52 AM #1Junior Member
- Jan 2011
- pa
red- 1994 camaro
heater core hoses
heres my story back on jan 11th i had to have my heater core replaced at a well known national shop i know iknow i should have done it my self but it was frezzzzzzzing cold out. So they replaced it. Last week it started to leak so i took it back to them they replaced it no poblems there. NOW I HAVE NO HEAT there is heat at idle but not going down the road i looked and it looks like the heater hoses are on backwords meaning it looks like the on thats on the left should be on the right . I did check and there is coolant im pretty sure there is no air pocket i drove the car about 50 miles since also when i got it back home from the shop i opened the rad cap with engine running never shut it off the coolant was not hot i put my finger right in it . Its a 1994 camaro v6 3.4L . So my question is this could somebody send me a heater hose diagram or take a pic of there heater hoses at the heater core and send it to me. I did call the shop and they said it must need a T-STAT now the car did have heat b4 they replaced the heater core any help would be great thanks
02-23-2011, 03:11 PM #2
Reversing/switching the core hoses will only let coolant flow the oposite direction through the core..
It will not cause there to be a loss of heat..
You either have a clogged rad or more than likely you have an air pocket issue and/or a thermostat issue..
If you mileage is high could even be a bad water pump starting to show..
02-23-2011, 03:58 PM #3Junior Member
- Jan 2011
- pa
red- 1994 camaro
ok well 2day i decided to take things apart and low and behold i found the orange vacum hose that goes to the blend door actuater to be broken off and the part is no longer available
02-23-2011, 10:47 PM #4
02-24-2011, 08:24 AM #5Junior Member
- Jan 2011
- pa
red- 1994 camaro
super glue and jb weld and now there is heat
02-25-2011, 03:30 PM #6Junior Member
- Jan 2011
- pa
red- 1994 camaro
thought i had heat but nope
ok at idle 140 degress at 65mph maybe 100 degress comeing out the center vent. At idle temp gauge is half way at 65 mph temp gauge is only quater way up they replaced the heater core on monday b4 they did i had heat after they replaced the heater core i get what i just describe all vent doors are working the way they are supose to and a new t-stat was put in yesterday im one of those guy who always has a thermometer in the center vent b4 they replaced the heater core i had a vent temp at 65 mph of 120-125 basicly i had good heat b4 they put the warrenty heater core in
02-26-2011, 07:54 PM #7
Sounds like what my malibu was doing turned out to be head issues.
dont want a heater, heater hoses
By tomcamaro97 in forum External EngineReplies: 2Last Post: 05-22-2014, 06:17 PM -
Heater Core Problem?
By BirdCountry02 in forum General HelpReplies: 18Last Post: 12-30-2010, 04:55 PM -
Heater hoses where can I buy them?
By carnutt in forum External EngineReplies: 5Last Post: 07-14-2009, 10:05 AM -
Heater core inlet/outlet hoses
By 01SS in forum Parts Wanted / TradeReplies: 1Last Post: 05-22-2009, 10:36 AM -
'99 Heater core replacement
By jad628 in forum General HelpReplies: 3Last Post: 11-08-2006, 04:54 PM
