Results 1 to 3 of 3
    Mar 2009
    Brighton, MI
    pewter
    2000 CAMARO SS
    58mm BBK throttle body hoses problem, please help
    I have a 58mm BBK throttle body. For whatever reason when I went to re-hook up all the hoses, I am missing one and was hoping someone can tell me where it goes.
    If you are looking at throttle body from the front of the car, on the left (passenger side) there are two inlets where hoses hook to the throttle body. The top left inlet goes to the valve cover to recirculate air (I'm guessing). The lower left inlet goes to ?????? It's driving me nuts and I can't find a diagram online or in my chilton. It is a major vacuum leak and when I started it with this off, obviously good sounds were not heard.
    If you know what hose connects here and where it is going, I would really appreciate the info.
    I already did the tb-bypass so its not for that. Here is a link to a picture of the BBK 58mm throttle body.
    http://www.bbkperformance.com/produc...ttle-body.html
    What is the lower left 'nipple'/inlet connect to?
    Thank you.
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    It's called the Evap canister purge solinoid. It's half way down the fuel rail inbetween the fuel rail and the valve cover
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    It should be a hard plastic vac line with a rubber 90 that more than likley fell appart when you took the stock one off. They are usually in bad shape after 5 years on a dd
  1. WTB 52/58mm throttle body lt1 1994
    By balls51 in forum Parts Wanted / Trade
    Last Post: 09-03-2008, 06:47 PM
  2. Throttle Body size 52mm or 58mm?
    By 97ramair in forum LT1
    Last Post: 12-15-2007, 09:18 AM
  3. 1993 LT1 58mm Throttle Body
    By sped in forum Parts For Sale / Trade
    Last Post: 12-15-2006, 07:29 AM
