Results 1 to 10 of 10
    Member Blue28's Avatar
    Ca.
    Navy Blue
    1999 Camaro Z28
    Thumbs up New Slave cylinder? Pilot bearing or bushing?
    Ok, i just ordered a LS7 clutch kit with an aluminum flywheel from SDPC for my 99 Z28, so I have a question. Do I need to get a new slave cylinder, and should I get a Pilot bushing or Pilot bearing, Is one better than another?
    Thanks!
    Member flipsutter's Avatar
    May 2008
    Arkansas
    1999 Firehawk
    Not sure if you have ordered or not but you should go ahead and replace the pilot bearing and the slave. Since you can get to both any way while its out. Also I replaced my rear main seal with it was out too.
    And check your oil sending unit. Mine was leaking but I forgot to change it while the transmission was down. I'll do it when I change out the intake.
    Ca.
    Navy Blue
    1999 Camaro Z28
    Wink
    Yeah, I went ahead and ordered a new rear main seal, pilot bushing, and slave cylinder.
    thanks!
    Junior Member jc99ls1ss's Avatar
    Louisiana
    Bright Red
    1999 Camaro SS
    it should have bearings in it. Mine did in my 99 ss. I have used both but the just plain bushing was in an old truck of mine.
    Pittsburgh
    2008 Hummer H3
    Be carefull when removing the pilot. You may already know this but there's a oil plug in behind the pilot. If you damage it or push it into the crank you'll be kicking your own ass over it..
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    Exactly. There is only one proper method to removing the pilot bearing on these engines, and thats with a pilot bearing puller and/or slide hammer, pulling it straight out. If you try and use the method where you fill it with grease to push it out from the inside, you will end up with a core plug in your oil galley. Not good.
    Ca.
    Navy Blue
    1999 Camaro Z28
    Question
    So what does a pilot bearing puller/slide hammer cost?
    That's something I know I don't have.
    Any recommendations on one would be great!
    Thanks!
    NJ
    SGM
    1998 Trans Am WS6
    Quote Originally Posted by Blue28 View Post
    Thanks!
    You can rent one from most auto parts stores (Advance, Autozone, ect.) for free. You just pay for the tool in full, use it, and then when you bring it back they give your full deposit back.
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    Thanks!
    Or if you have dremel tool, you can grind and cut the old bearing out. Just be careful!
    Member 99yellowz28's Avatar
    akron,oh
    competition yellow
    1999 camaro m6
    Thanks!
    I just rented a slide hammer from advance auto yesterday to do my pilot bearing its a $130 deposit
  1. Help: Pilot bearing removel?
    By kingls1 in forum Manual Transmission
    Last Post: 04-29-2013, 09:35 PM
  2. Throw-out bearing or Pilot Bearing going out? Need help.
    By werewolf in forum Manual Transmission
    Last Post: 04-11-2013, 05:19 PM
  3. Question: Pilot bushing or bearing?
    By lsgunner28 in forum Manual Transmission
    Last Post: 07-27-2010, 08:34 PM
  4. Damn Pilot Bearing
    By reils1 in forum Manual Transmission
    Last Post: 05-10-2008, 04:15 AM
  5. Pilot bushing Bearing Removal need suggestions
    By Zak in forum Internal Engine
    Last Post: 08-10-2006, 04:22 AM
