Results 1 to 14 of 14
    Senior Member kingls1's Avatar
    Apr 2011
    Johnstown,PA
    1999 Trans-Am, 2012 Sonic
    Pilot bearing removel?
    Getting ready in a few weeks to put in a new Ls7 clutch and have been doing some reading on install and gathering parts and tools.
    Any help on the best way to remove the pilot bearing, was reading over on Tech and some Vette forms that a Blind Hole Puller set is the best tool to remove the bearing
    Anyone have any info or tools used?
    No interest in using grease, bread, or paper smashed in to force it out, sounds like trouble to me.....
    Senior Member redbird555's Avatar
    Mar 2009
    pompano beach florida
    2002 Camaro Z/28 Pewter
    Quote Originally Posted by kingls1 View Post
    i used the puller and it worked great no problem
    Apr 2011
    Johnstown,PA
    One more thing to add to this question, may sound dumb but about how much clutch fluid is needed when changing fluid?
    I have the factory service manual and it tells the capacities of almost everything but only list's DOT3 fluid. Fluid I'm using comes in a12oz bottle...searched all over still nothing!
    - - - Updated - - -
    Quote Originally Posted by redbird555 View Post
    Thanks sound about right from other reads
    I have had success using seal pullers on pilot bearings.
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Apr 2011
    Johnstown,PA
    Looking for the capacities of the clutch system(amount of fluid) it would take to flush system.
    Comes in 12oz. Bottle do I need one, two or ten?
    Trans. Holds 4quarts, rear 3.6 pints, motor 5quarts, nothing listed for clutch system!
    Thanks for the links
    As I mentioned, not sure on your question of how much
    Mar 2009
    I'm not dsure exactly how much but I can tell you, it holds less than that small bottle of fluid so not much. however you will waste a lot of it bleeding. I just bought the larger container and had a little left over after bleeding, even with starting over couple times
    If you want to measure how much you use, I'll add it to my sticky as a guesstimate.
    Apr 2011
    Johnstown,PA
    Thanks for the info, what fluid do you recommend ( Brand) is the best for our systems? I was going to use Amsoil but my parts guy don't stock Dot3 brake fluid.
    Apr 2011
    Johnstown,PA
    I will do that and let you know Jon
    Member bberretta's Avatar
    Aug 2009
    Memphis, TN
    Bright Red
    2000 TA Firehawk 0041/742
    My pilot bearing was a "worse case scenario." I broke the teeth off the puller that I had rented.
    I ended up using a Dremel with a Tungsten Carbide bit (bit 9901) to grind out two spots at 9 o'clock and 3 o'clock and it popped right out. I didn't have to cut it all the way through- just cut it most of the way through and then when I hit it with a new puller I was able to split it in half. Takes a steady hand and some patience.
    2000 Pontiac Firehawk #0041 of 742
    Apr 2011
    Johnstown,PA
    Hope I don't run in to that! With winter hanging on so long up here and now the painter on my new hood taking his sweet time I'm still waiting to tear into the clutch. Hopefully soon, thanks for the input, don't want to use it but if need be I will have the upper hand
    Aug 2009
    Memphis, TN
    Bright Red
    Your best bet is to be prepared for anything- best or worse case. Have your puller ready but go ahead and have the dremel out on the work bench. Be careful and don't push the puller too far into the hole- there is a freeze plug behind it that can be pushed in too far. Go ahead and get a rear main seal set and swap it out while you've got it apart. Those are the best bits of advice I can give you having put the LS7 clutch in my 'Hawk back in 2010. The only real difficulty was the pilot bearing, other than that it all went in easily.
  1. Throw-out bearing or Pilot Bearing going out? Need help.
    By werewolf in forum Manual Transmission
    Last Post: 04-11-2013, 05:19 PM
  2. Question: Pilot bushing or bearing?
    By lsgunner28 in forum Manual Transmission
    Last Post: 07-27-2010, 08:34 PM
  3. Does it take a genius to get out my pilot bearing?
    By getcha01 in forum Manual Transmission
    Last Post: 02-06-2009, 03:55 PM
  4. Damn Pilot Bearing
    By reils1 in forum Manual Transmission
    Last Post: 05-10-2008, 04:15 AM
  5. Pilot bearing question
    By hissin'98 in forum Manual Transmission
    Last Post: 10-12-2005, 06:18 PM
