Thread: Pilot bushing or bearing?
07-26-2010, 05:53 PM #1
Hi all,
do the M6 need either? I cant find them on summit..
thanks2000 Z28 M6 125,XXX: SLP lid, K&N, 10.4mm Taylor plug wires, Frost Tune, P&P TB, NGK Iridium plugs, Magnaflow Cat back, BMR SFC's and tower brace, TSP LT's and ORY, LS6 intake, MAC Girdle, UMI LCA's and Panhard, LS7 Clutch Kit, so far..
07-26-2010, 06:54 PM #2Exalted Cyclops
- Feb 2007
- San Diego, CA
AFAIK, all manual tranny's need a pilot bushing/bearing on the end of the crank that will accept the input shaft of the tranny.
67 Camaro: K-K + 797-z (look it up), 454/Th400/4.10 12-bolt = 6mpg, PS/PDB/PW tilt, tach, gauges...
Carbon footprint? CLOWN SHOE!
07-26-2010, 09:55 PM #3
GM Parts Direct - part number 14061685.
Real PITA to remove. Get a Dremel with a Tungsten carbide cutting bit. Once you grind it out a bit on opposite sides (say, at 9 and 3 o'clock) use a pilot bushing removal tool to pop it out.Last edited by bberretta; 07-26-2010 at 10:04 PM.
07-27-2010, 02:18 AM #4
thanks guys
07-27-2010, 04:19 PM #5
is it easier to separate the bell housing from the transmission for re-install? removing it was a PITA! the bolt holes on the bell housing were jammed tight to the firewall..
07-27-2010, 08:34 PM #6
I kept the bell housing seperate from the trans. Get 13mm and 15mm u-joint sockets and an extension that's at least 24" to 36". That's the trick to getting to a couple of the bolts.
Throw-out bearing or Pilot Bearing going out? Need help.
By werewolf in forum Manual TransmissionReplies: 3Last Post: 04-11-2013, 05:19 PM -
FS: LS7 Clutch, LS1 Pilot Bearing
By GoldenFlame in forum Parts For Sale / TradeReplies: 2Last Post: 05-23-2012, 07:18 AM -
New Slave cylinder? Pilot bearing or bushing?
By Blue28 in forum Manual TransmissionReplies: 9Last Post: 09-30-2009, 07:25 AM -
Damn Pilot Bearing
By reils1 in forum Manual TransmissionReplies: 6Last Post: 05-10-2008, 04:15 AM -
Pilot bushing Bearing Removal need suggestions
By Zak in forum Internal EngineReplies: 7Last Post: 08-10-2006, 04:22 AM
