Results 1 to 20 of 22
Thread: Low Voltage @ Idle with A/C on
08-12-2009, 08:42 AM #1Junior Member
- Oct 2008
- Monroe,Michigan
Silver- 2000 TA LS1 A4w/ShiftKit
When I am sittn in traffic or at a stop light with the A/C on the voltage drops pretty low. But any other time it is fine. What could possibly be the problem ?
08-12-2009, 09:24 AM #2Single Malt
- Ft. Lauderdale, FL
Sebring Silver- 2000 CamaroSS
Your fans coming on are a big drain. If you watch, you'll see when they go off, the voltage goes back up.
It all depends on how low whether or not something is wrong.
08-12-2009, 12:05 PM #3the cake is a lie
- Sep 2005
- hopewell jct, ny
black 01 red 73- 01 z28 and 73 z28
a lot of voltage is used to pull the clutch in on the compressor also the blower motor, cooling fans (as stated) etc . as long as your not in the red it OK
08-14-2009, 12:41 PM #4
08-14-2009, 06:27 PM #5Member
- Nov 2008
- harrisburg pa.
black- 02 vette vert
what rpms are you showing in gear when volts are low? may be just a low idle speed, mine never goes below 13 volts in those conditions, if it even gets down to 13. and yes you should worry about it, anything below 12.5 and your electric accessories are draining your battery.
08-16-2009, 07:48 PM #6
Do you have underdrive pulleys? And check the grounds make sure they have a good connections
08-17-2009, 04:09 PM #7
08-17-2009, 11:45 PM #8
All the grounds,one from the battery to the engine block, just saying I always go easy stuff first, and makeing sure the electrcal system is in good working order. Cables and connections, no voltage drops that are excessive, the simple stuff that haunts you later.
08-18-2009, 06:34 AM #9Junior Member
- Oct 2008
- Monroe,Michigan
I believe I am having some ground issues somewhere. My turnsignals/parking lights are being weird. The left doesnt work when the car is started and the right is really bright until I turn on the parking lights then the left comes on dim and the right super bright. My left front turnsignal is not working at all and when I turn on the headlights both parking lights come on about normal. When I click the keyless entry both parking lights flash the normal brightness. I checked the grounds on the radiator brace as some1 on here told me to do but still no luck.
08-18-2009, 07:09 AM #10
if your blinker is bright on one side and the other does not work that should be a bulb issue. I have a racetronics fuel pump harness and I see a major voltage drop with both fans on. checking it this week to see if it is too significant.
08-18-2009, 08:08 AM #11
08-18-2009, 08:23 AM #12Single Malt
Yes, the bulbs are dual filament. The turn signal runs on the bright filament, the DRL's run on the less bright. The flash is from the less bright filament.
Don't use GE bulbs.....use only Sylvania.....The # is 3157K. Side markers are #194Last edited by rbob93; 08-18-2009 at 08:35 AM.
08-18-2009, 09:30 AM #13
What's your engine idle rpm with the AC on, and is it the same as when it's off?
08-18-2009, 01:44 PM #14
08-18-2009, 01:46 PM #15Junior Member
- Oct 2008
- Monroe,Michigan
I am going to take her out for a lil spin right now. I will check the RPM's both ways AC on idle and AC off idle. I will let u know.
Seen optima batteries have a $25 mail in rebate here in Michigan. Jus a lil FYI for ya guys. I dont know peoples takes on Optima batteries but here they are supposed to be the best.
08-18-2009, 05:03 PM #16
08-19-2009, 08:16 AM #17
08-19-2009, 08:31 AM #18
IMO, that's to low.
Did you have it tuned to have the idle that low or did you use a hand programmer?
I would have the idle bumped up to around 650-700rpm, I run mine at 850rpm with the AC on, and 800rpm with the AC off.Last edited by Blue28; 08-19-2009 at 08:44 AM.
08-19-2009, 09:41 AM #19
08-19-2009, 11:50 AM #20Member
- Nov 2008
- harrisburg pa.
idle issues... idle high. unplugged tps runs good?
By okiels1 in forum Firebird / WS6Replies: 2Last Post: 12-31-2016, 03:36 AM -
How do you check voltage going to Idle air control valve?
By Street Fighter in forum General HelpReplies: 3Last Post: 05-28-2015, 03:08 AM -
How To Fix Idle Problems - Idle Time
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 04-05-2012, 07:50 PM -
Help: intermittant rough idle, off idle hesitation
By Matto4785 in forum General HelpReplies: 1Last Post: 09-21-2009, 05:12 AM -
Low voltage
By Art99SS in forum General HelpReplies: 1Last Post: 06-02-2009, 03:34 PM
