Results 1 to 2 of 2
08-05-2009, 06:36 PM #1Member
- May 2009
- Kansas
Black- 1999 T/A WS.6
Headlight help. Not the normal gear issue.
So about a few months ago, my headlight gear became stripped. I did the easy fix, and rotated it 180 degrees, right?
Anyway. I just went to put some gas in her to keep her above a quarter tank. And when I flipped my headlights up.. all of a sudden the grinding occurs. Same sound as when it was stripped. But the light goes up about 95% of the way and then just grinds before kicking itself all the way up.
Any ideas? The grinding instantly stops if I lift the light up manually as soon as it raises.
EDIT: The headlight does not go up/down when I use my keyless entry like the normal stripped gear. It's almost like the whole mechanism isn't lifting the light up, or doesn't have the willpower to.Last edited by MistrCreazil; 08-05-2009 at 06:41 PM.
08-06-2009, 08:05 AM #2Just a farmboy
- Jun 2007
- Montpelier, VA
Pewter- 2000 Pontiac Trans Am
check to make sure the gear housing is glued tight. mine came unglued once and did the same thing. i used 4 zipties to keep it close together. looks shitty, but it works nonetheless
headlight over-tightening itself? (not a plastic gear issue)
By justinmc978 in forum Firebird / WS6Replies: 0Last Post: 09-29-2012, 02:51 PM -
Help: Not your normal headlight problem
By KillerCasey915 in forum Firebird / WS6Replies: 14Last Post: 12-28-2011, 09:11 AM -
Headlight issue
By FutureWS6 in forum Firebird / WS6Replies: 17Last Post: 01-20-2011, 02:18 PM -
How much gear whine is normal?
By SouthernBornThriller in forum Manual TransmissionReplies: 19Last Post: 07-03-2009, 09:14 AM -
Headlight issue, fairly certain its not the gear
By Matto4785 in forum General HelpReplies: 1Last Post: 06-25-2009, 02:48 AM
