Results 1 to 20 of 20
    Charlotte, NC
    Black 2002 T/A M6
    Green 1997 Ram 4x4
    How much gear whine is normal?
    The T/A is my first manual car, so I'm about as familiar with manual trannies as Hugh Hefner is with fat chicks.
    Anyway, had the thing since last summer, and I hadn't really paid much attention until I took a fairly long trip (8 hrs) in the car a couple months ago. After a couple hours the gear whine stuck out over the exhaust, radio, everything. Just resonates inside the car as well. Seemed like I was stopping at every rest stop to let my headache subside.
    Been paying closer attention to it now, and from the inside, it definitely sounds louder than my (stock) exhaust. Is that normal, or should I get it looked at ASAP?
    San Diego ca
    "Arrest Me Red"
    2001 trans am
    do you have a after market rearend and or shifter? you shoul not here the rear but if you have a shifter like a pro 5.0 you will here it a bit but it shouldnt be bad.
    Charlotte, NC
    Black 2002 T/A M6
    Green 1997 Ram 4x4
    Quote Originally Posted by 01 T/A View Post
    Shifter and rear are stock. I've been wondering about the gears since the car has a good bit more low-end bite than my previous Camaro (although it was an A4). The thought has crossed my mind that the previous owner may have done just a cheap gear swap, although from what I can see it doesn't look like it.
    Just wanted to find out how much (if any) gear whine is normal before I had the thing looked at.
    does it whine on accel, decel, or both?
    Charlotte, NC
    Black 2002 T/A M6
    Green 1997 Ram 4x4
    I actually hear it the loudest when maintaining higher highway speeds (hovering around 70-80), although this just could be from exhaust drowning it out during acceleration. It noticeably decreases when I let off the pedal and let her coast though.
    Marylandistan
    2001 Trans Am (sold)
    If it bothers you you can rebuild it but gear whine isn't gonna hurt anything. My Strange 12 bolt screams, if I rebuild it it'll just make noise again after a few trips to the track.
    Charlotte, NC
    Black 2002 T/A M6
    Green 1997 Ram 4x4
    Quote Originally Posted by INMY01TA View Post
    I like to drive, and it hurts my ears.
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    Are you sure it is gear whine? Is is a deep droning sound? Could be a leak in the exhaust or muffler.
    Coral Springs, Fl
    Sunset Orange Metalic
    Could just be tire noise at highway speeds.
    Maybe drone from the exhaust but stock probly not
    All i can think of besides the rear
    Charlotte, NC
    Black 2002 T/A M6
    Green 1997 Ram 4x4
    Quote Originally Posted by bigrondownhiller View Post
    Wouldn't I hear an exhaust leak at idle? Or at least when I rev the engine. It's just a steady, moderately high pitched noise that I notice around 50mph and gets annoying over 60mph.
    I hear it the worst at higher speeds with very light throttle (interstate cruising).
    I hadn't thought of an exhaust leak before, but it just sounds completely seperate from the exhaust. I could be wrong, but I would think that an exhaust leak would get louder as the exhaust does when throttle is increased, and would do it at all speeds. This is only at higher speeds, and is drowned out by the exhaust note if I stomp on the go pedal.
    Feb 2006
    Orange County, NY
    always dirty
    If it is high pitched then most likely not. Just was thinking of a lower drone that the exhaust might make depending on where the leak was.
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Well you should NOT be able to hear an audible whine. NO it's not normal.
    I have read MANY threads on here and other places where people have posted that it's normal to get a whine with after market gears. . . . . . .
    If the pinion depth and back lash are set-up correctly you shouldn't have noise. I have been doing this for over 15 years and over 10 for a living so I'm speaking from experience.
    houston
    Navy Blue
    ls1 trans am
    Mine wines like crazy too from 50-70 miles... had the dealership rebuilt it after a shop messed up by over tightening the pinion when replacing the seal. My solution... sub woofer, speakers, and amp.
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Quote Originally Posted by JehalinTA View Post
    That works too. I'm an avid audiophile so I have sounds in Everything I drive anyways.
    Phila, PA
    2002 ramair
    Mine did the same thing at about 40k miles. It was still under warranty. They rebuilt the rear and I brought it back the next day because it had a slightly different whine. The dealer admitted that the guy who normally did rears was on vacation. So I waited for him to return. When he re-rebuilt it he said the rear was not shimmed correctly (too tight). It has been quiet ever since. The stock rears in them are weak.
    Feb 2007
    San Diego, CA
    2002 Z28 A4 NBM
    Sadly now demodded :(
    I tried Motive gears (3.73 ratio) and that set whined like a whore that hadn't gotten paid.
    Next I tried Richmond. Better but still noticeable during coast and especially during decel.
    Now I've got AAM gears and couldn't be happier. If I didn't concentrate (with everything off) and/or know what I was listening for I wouldn't hear a thing. The wind going thru my 7 year old rubber seals around the door windows makes more noise now. I'm a happy camper.
    Junior Member Blackbandit's Avatar
    Dec 2008
    98 Trans AM
    Quote Originally Posted by LS2Tuner View Post
    Sorry to jump in here so late but are you saying that the whine from my gears is from incorrect installation? And if so, Can it be fixed by resetting the pinion depth and back lash, or is there something ruined now and I have to replace that too...
    Senior Member 00LS12LS6Z28's Avatar
    Bristow, VA
    2000 Camaro Z28 (sold)
    I only get a whine when I accelerate or if I am at higher RPMS, but cruising I don't hear a thing but the exhaust.
    Bristow, VA
    How many miles are on your car?
    Dec 2008
    98 Trans AM
    105 miles....last owner had 4:10's installed...I don't really hear it in first or second, not even really third where it is overpowering but in fourth and fifth and sixth, when I let off on the gas I don't hear anything, and when I jump on the gas I don't hear anything, it's just at cruising, slightly touching the gas and the pitch also increases with higher gear, to an overwhelming pearce at about 70 or 80. I'm just wondering if it's bearing, or gears, or what can I expect..I did have the fluid changed cause was leaking but didn't solve anything even with the additive.
  1. Question: Gear whine
    By migueelw in forum Drivetrain
    Last Post: 02-25-2009, 09:28 AM
  2. Gear Whine Problems
    By JattGunMan in forum Drivetrain
    Last Post: 01-09-2009, 02:52 PM
  3. Gear (whine)????
    Last Post: 09-24-2008, 11:47 PM
  4. Convertibles Hush Gear Whine
    By Z ROADSTER in forum Convertible
    Last Post: 12-16-2007, 02:31 PM
  5. 4.10 gear whine
    By Roastem in forum Drivetrain
    Last Post: 01-13-2006, 12:57 PM
