Thread: Gear whine
    Junior Member migueelw's Avatar
    NC
    Red w/stripes
    02 Camaro SS 35th Anniv.
    Question Gear whine
    What causes gear whine and is there a way to stop it?
    Member side2000's Avatar
    md
    2000 camaro ss
    where is it coming from? what speeds do you hear it? is it constant, increase with speed, or is it rpm related only.
    NC
    Red w/stripes
    It's coming from the rear. I hear it when I get around 40 mph. It's constant, speeds above 40 mph and I hear it even when I'm not accelerating.
    Quote Originally Posted by side2000 View Post
    md
    2000 camaro ss
    sounds like pinion or carrier bearing to me, not gear whine. might wanna look into a bearing rebuild. i have had to do my bearings multiple times in my car from bangin turns and road racin.
    2000 red ss: >2" drop, koni adjustables 'n 275 s-compounds all way around, giant brakes, dynatech LT's, borla catback (no plate), t56, tubular everything, HARD TOP, caged, "stock" heads 'n a mean cam. -2* front camber.
    NC
    Red w/stripes
    Thanks
    Member barryz's Avatar
    roosendaal , netherlands
    2000 transam ram air WS6
    I had a lot of noise coming out of my rear axle the first garage tells me my hole axle needs to be replaced . then i went to my neibhor he works on race cars
    he took my hole axle apart and everything looks brand new !!!! he changed the oil ... racing oil no more noise it's unbelievable no more grinding
    i am very happy with the results !!!!!!
    md
    2000 camaro ss
    synthetic gear lube does wonders for rear axle components. it's 1000% better than conventional stuff.
    NC
    Red w/stripes
    Quote Originally Posted by barryz View Post
    If I'm understanding correctly, you had grinding coming from your gears and all you did was put racing oil in it and it stopped completely.
    What type of rear end do you have?
    Senior Member clg82's Avatar
    Feb 2007
    California
    2000 Trans Am
    I had new gears installed last Friday, and I have NO GEAR WHINE at all!! It is all in the install.......
    Member stephen02ws6's Avatar
    Dalzell, Illinois
    red with black stripes
    2002 Trans Am WS6
    i believe its how you install and break them in.
    Feb 2007
    California
    2000 Trans Am
    Umm I think I may have already said that?
    Quote Originally Posted by stephen02ws6 View Post
    Dalzell, Illinois
    2002 Trans Am WS6
    ya i know, just backin you up
  1. How much gear whine is normal?
    By SouthernBornThriller in forum Manual Transmission
    Last Post: 07-03-2009, 09:14 AM
  2. Gear Whine Problems
    By JattGunMan in forum Drivetrain
    Last Post: 01-09-2009, 02:52 PM
  3. Gear (whine)????
    By migueelw in forum Drivetrain
    Last Post: 09-24-2008, 11:47 PM
  4. gear whine or worse trouble(again)
    By Matto4785 in forum Drivetrain
    Last Post: 03-19-2006, 03:28 PM
  5. 4.10 gear whine
    By Roastem in forum Drivetrain
    Last Post: 01-13-2006, 12:57 PM
