    Jul 2009
    columbus
    2000 WS6 TRANS AM
    No Error codes - poor running LS1
    Hey everyone, I'm new to the site but have owned my 2000 WS6 for 9 years. I'm having a performance problem that seems to be getting worse. I occasionally spudder under normal driving conditions. It feels like I lost my fuel pressure or have no fuel to the injectors. I don't get an error code, I have 55-60 psi at the fuel rail, I have reset the error codes, changed spark plugs, cleaned the throttle body, changed plug wires, changed 2 o2 sensors and am now in process of checking vacuum system. My car will run okay most of the time after it is up to speed but when I push on the pedal hard the car will drop out or then surge if I keep the pedal down. it was a daily driver but has not had many miles put on it in the last 2 years. I thought it was a transmission problem at first and then the dealer told me it was a fuel pump problem? If I have 55-60 psi when I'm driving how can I be sure the fuel pump is bad???
    Jul 2009
    columbus
    2000 WS6 TRANS AM
    found the problem!!!!!!!!!!!
    After looking through some Threads and inspecting my Intake Air Temp. sensor I found that it had no resistance at all...it was wide open......I got a new one from AdvanceAuto for 12.99 and cleaned the MAF.....running like a champ.....I got my 325 horses back.........
    ******The dealer wanted 1300$ to pull the fuel pump out and replace it******LS1.com just saved me a lot of cash..............
    Thanks, Matt
    pa
    Wow nice you were able to find your trouble on your own. Didn't it set any codes?
    glad to hear you got it running right.
    Jul 2009
    columbus
    2000 WS6 TRANS AM
    Yeah....no codes except for an occ. 02 sensor code when I was running it hard to diagnosis the problem???
    Member DaddySS's Avatar
    Bergen Co. NJ
    2000 Camaro SS Conv.
    Excellent, and thanks for updating us.
  1. Help: P0171 and P0174 error codes
    By initechpeter in forum Firebird / WS6
    Last Post: 09-19-2013, 03:48 AM
  2. error codes help
    By leon phelps in forum Computer & Tuning
    Last Post: 02-13-2012, 01:21 PM
  3. Question: It's back???? poor running 2000 WS6
    By mm3306 in forum Internal Engine
    Last Post: 04-25-2010, 08:22 AM
  4. Got some error codes...
    By Hedghog in forum General Help
    Last Post: 05-31-2009, 11:42 AM
  5. Error Codes
    By Phlash_riot in forum Computer & Tuning
    Last Post: 09-28-2006, 06:22 PM
