Thread: Error Codes
    Member Phlash_riot's Avatar
    Aug 2006
    San Diego
    Midnight Blue
    1999 T/A
    Error Codes
    My service engine soon light came on.. how to i get it to spit out the codes?
    near St. Louis
    navy blue
    2002 Z-28 Camaro M6
    You need an OBDII code reader hooked in the connector under the dash. If you go by Autozone or similar joint-they will read the codes for free.
    Aug 2006
    San Diego
    Midnight Blue
    1999 T/A
    no way to get the codesto show up in the milage area on the dash.heard someting about the radio showing some codes. its on a 99 TA
    Blown, Stroked, & Sprayed
    Ed Blown Vert's Avatar
    Aug 1999
    No Where
    383 Procharged & N20 Vert
    Nope, you have to scan it
    Senior Member
    Jacksonville, FL
    Yep - hopefully it's something easy - write down the code and post it.
    Aug 2006
    San Diego
    Midnight Blue
    1999 T/A
    Just as a side note before i go to autozone... when i get low on gas my check gauges light comes on.... if i go further on "E" will the service engine light come on later?
    Aug 1999
    No Where
    Quote Originally Posted by Phlash_riot View Post
    Just as a side note before i go to autozone... when i get low on gas my check engine light comes on.... if i go further on "E" will the service engine light come on later?
    If you get low on gas. You should see the check gauges light. Not the Check Engine Light
    Aug 2006
    San Diego
    Midnight Blue
    1999 T/A
    That's what i thought but i was hoping for the best.... ....
    Senior Member
    Jacksonville, FL
    Running extremely low on gas/running out can throw a code. Be nice to your fuel pump (and your walet) and always get gas when the gauge falls below 1/4.
    Aug 2006
    San Diego
    Midnight Blue
    1999 T/A
    I am guessing that you have to have a scanner to clear the codes as well..... besides disconnecting the battery
    Aug 1999
    No Where
    Senior Member
    Jacksonville, FL
    You can reset the PCM and see if it comes back...personally it would drive me nuts not knowing what it was.
    Turn key on, don't start car
    Pull PCM BATT and PCM IGN fuses in engine compartment
    Wait 5-10 min
    Turn ignition off
    Replace fuses
    Warning: Idle will be grumpy until it relearns and readiness tests will be reset.
  1. Help: P0171 and P0174 error codes
    By initechpeter in forum Firebird / WS6
    Last Post: 09-19-2013, 03:48 AM
  2. error codes help
    By leon phelps in forum Computer & Tuning
    Last Post: 02-13-2012, 01:21 PM
  3. No Error codes - poor running LS1
    By mm3306 in forum General Help
    Last Post: 07-24-2009, 04:00 PM
  4. Got some error codes...
    By Hedghog in forum General Help
    Last Post: 05-31-2009, 11:42 AM
  5. The End of an Error
    By Max Power in forum Political / Debate Forum
    Last Post: 01-22-2009, 03:04 PM
