Results 1 to 10 of 10
Thread: CAMS
07-15-2009, 01:38 PM #1
CAMS
Ive been wanting to cam my car i want streetability with good performance ive heard a lot about the torqer v2 but I dont have headers or an aftermarket intake was woundering if its ok to cam it w/ stock manifolds and intake for now i will get that stuff eventualy. please list your setups.
07-15-2009, 02:06 PM #2
Sure it is. But you will not see near the potential of the cam with out the right supporting mods. Your going at it backwards honestly. That LS1 intake will kill you, its the worst intake out. No headers ( Im assuming no exhuast work at all) will also kill any cam added HP. Sounds like you have a completely stock car, and want a cam. If thats really what you want, go for it. It will be disappointing though. Get a LS6 intake or better, a decent pair of longtubes, then start thinking about a cam.
Build in progress...
07-15-2009, 03:01 PM #3
hi po u never sounded so right..
07-16-2009, 03:37 PM #4
that was an epic explanation
07-16-2009, 04:11 PM #5
07-18-2009, 05:53 PM #6
I see what you guys are saying i would like to do the weiland intake but the problem is headers i have a borla setup but the stock ypipe scrapes on everything and a 3in y pipe will not fit for my driveway
07-18-2009, 10:10 PM #7
fix ur drive way or get atv to get to ur car and park its some where eles... and dont do twin cut out on the y pipe.. b/c i hit shit every day ...
07-19-2009, 07:10 PM #8
Why is the ls6 intake better an what is a twin cut out on the y pipe ?
07-19-2009, 08:00 PM #9
bigger opening and better runners inside the intake. makes for a better power band from start to beginning just by itself. cutouts are holes in the exhaust pipes which can be closed. it allows for the exhaust to flow better and it much louder than an enclosed exhaust. but again you can close whenever though.
07-20-2009, 11:56 AM #10
A good tuner can make most cams streetable. The 224 is a good cam with good streetability from what I read. 228R and 230 will get you a bit more power though.
Cams
By navyLS1 in forum Internal EngineReplies: 7Last Post: 11-03-2009, 10:34 AM -
Looking at some cams.
By RyanJM in forum Internal EngineReplies: 4Last Post: 03-08-2009, 06:56 AM -
TSP MS3 and MS4 Cams?
By Sunset T/A in forum Internal EngineReplies: 22Last Post: 09-27-2007, 10:14 AM -
Comp Cams New Thumper Cams
By Z ROADSTER in forum Internal EngineReplies: 6Last Post: 08-27-2007, 12:39 PM -
cams ????
By Ridinfilthy in forum Camaro / SSReplies: 5Last Post: 02-04-2007, 05:10 PM
