Results 1 to 10 of 10
07-12-2009, 07:03 AM #1Junior Member
- West Palm Beach, FL
Black- 1999 WS6 Conv.
AC Delco 9mm wires & AC Delco Iridium plugs
I read the sticky above ... but could not find any mention of the 9mm wires from Ac Delco. I was wondering if anyone has had experience with them as well as the Iridium plugs.
I am asking because I already had them on order before I researched and will gladly cancel and change to what would be a better combo.
Any help ?________________________________________
99 WS6, Black Vert M6
Lid, K&N, PPTB, PRC 2.5 heads, Comp Cam 228/.588 112 lsa w/ suporting mods, 96mmNW TB,102mmFast, Pacesetter LT's, ORY, Magnaflow, Tune, 4:10's, Aurburn Posi, LS7 Clutch, B&M shifter, Stano/ Koni , 18" C6 rims, 295/30 Kumho tires.
07-12-2009, 07:26 AM #2
Never ran those wires. Just MSD.
Im currently running those plugs, coming from NGK. They are expensive and made to last longer then NGK TR's. I got them cheap, and have no plans of running them any longer then my NGK's. They are good plugs though.370 CI - Twin 6766 Turbo - Jakes stage 5 4L80E - MWC 9" - Holley Dominator
Build in progress...
07-12-2009, 02:23 PM #3Single Malt
- Ft. Lauderdale, FL
Sebring Silver- 2000 CamaroSS
Gap for the iridiums should be set @ 1.01mm or .040
07-12-2009, 04:23 PM #4Junior Member
thanks, thought they came pre gapped .. I will be sure on that.
07-13-2009, 04:24 PM #5
07-14-2009, 01:20 PM #6Junior Member
are we sure about .040, the plugs at TSP are pre gapped at .55 ?
NGK TR55-IX Iridium Spark Plugs
NGK TR55-IX Iridium Spark Plugs for Stock Heat Range, Gapped at .055"
07-14-2009, 01:34 PM #7
I think hes referring to the ACD. Here, read this recent thread. http://www.ls1.com/forums/showthread.php?t=117637
07-14-2009, 01:54 PM #8Single Malt
You asked about AC Delco plugs & that's the info I responded for, but glad you want to be sure.
Here's the TSB on it.
http://www.acdelcotechconnect.com/pd..._03D-J-171.pdf
They were using the large gap (.060) for the platinum plugs which were OEM.
NGK TR55 is a copper plug. Guys have gapped them anywhere from .060 to .035 from what I've been reading here.
NGK TR55IX is an iridium plug. I have them gapped in my car @ .045
Sorry if I confused you.Last edited by rbob93; 07-14-2009 at 01:56 PM.
07-15-2009, 04:11 AM #9Junior Member
The confusion is on my part, sorry.
At this point I am considering returning the Ac Delco Iridiums & wires. Replace with MSD wires & NGK plugs.
My reasoning is, I can't get any feedback re: resistance on the AC Delco 9mm wires so I may as well go with what we know re: MSD. As far as the plugs go what is your opinion on the AC Delco Iridiums compared to NGK.
07-15-2009, 08:04 AM #10Single Malt
I went with the iridiums for the long service they provide. Some of these cars now have to be dismantled to change plugs.
This is what they made them for.....cars so inaccessable that they could run a plug reliably 100K miles.
Copper plugs have a short service life & I rather not change plugs every 12K to 15K.
I'm pleased with the iridiums. No noticible performance gain, just run for a longer interval.
50K on them is coming up soon & I'll change them out to see what condition they are in.
I'm running the NGKTR55IX BTW.
Also, there's nothing wrong with the OEM ignition cables. They do just fine for our cars.
Spark Plug Gap on AC Delco 41 110 Irradium Plugs.
By Z34LS1 in forum General HelpReplies: 35Last Post: 05-21-2020, 11:48 AM -
Taylor Thundervolt Plug Wires/ NGK TR55IX Iridium Spark Plugs
By Senator in forum Parts ReviewReplies: 3Last Post: 01-13-2016, 07:50 AM -
NGK Iridium OR Ac Delco Iridium Spark Plugs..
By tyxpx in forum External EngineReplies: 44Last Post: 09-06-2007, 05:50 PM -
Ac Delco Iridium Spark Plugs...
By bolden3 in forum General HelpReplies: 10Last Post: 08-25-2007, 08:05 AM -
AC-Delco Iridium plugs
By jad628 in forum General HelpReplies: 30Last Post: 03-23-2007, 08:56 AM
