Results 1 to 20 of 36
    Member Z34LS1's Avatar
    Indiana
    92 LS1 Lumina A4
    00 Formula WS9
    Spark Plug Gap on AC Delco 41 110 Irradium Plugs.
    O.K. so I searched through the Forums and find Gaps of .045 to .06
    Seems Gap is related to Add ons....
    My car is Stock other than True Duals, Cold Air Intake and the Tune that's going to Happen Tomorrow.
    I have New 9mm Wires and New 41 110 Spark Plugs to Install tonight.
    Setting the Gap seems to be a non Science after Reading Here.
    The 41 110's I bought are all Gapped at .04 I'm going top run them there.
    I found this online:
    SPARK PLUG. Glow) Spark Ignition. .
    This fits your Chevrolet Camaro.
    Stock Code 12621258
    Fitment Notes Pack of 8.
    Your Price $ 78.08
    Installation Instructions N/A
    Additional Notes
    Alternate Stock Code 12571164; 12609877; 41-110; 41110; SEEPCN
    Categories Electronics, Charging, Wiring and Ignition > Spark Plug
    Assemblies
    Manufacturer GM
    Quantity to add
    Ask A Question About This Product
    Product Assemblies
    Image Name Description Product Application Notes
    NORMAL MAINTENANCE REPLACEMENT PARTS (LS1/5.7G); LS1 - ENGINE GAS, 8 CYL, 5.7L, SFI, ALUMINUM ENGINE; M30 - TRANSMISSION,AUTOMATIC 4 SPEED,4L60E,ELECTRONIC; PLEASE REFER TO YOUR OWNER MANUAL FOR (NORMAL)SCHEDULED MAINTENANCE PARTS; SPARK PLUG,(GAP 0.040)(DO NOT CHANGE SPARK PLUG GAP FROM .040)(ACDelco #41-110)(IRIDIUM). SPARK PLUG, Engine Tune-up(Spark,Glow). For: F 5.7G(LS1) (1998-2002) (1998 - 2002). Required: 08
    Indiana
    92 LS1 Lumina A4
    00 Formula WS9
    Previous owner had installed Bosch R3 Platinum 2 Plugs. These were Dual Electrode Plugs, 2 of the Plugs, Bank 2 and Bank 6 1 of the Electrodes were touching the Platinum. Unreal, can't wait to get the new plugs in.
    - - - Updated - - -
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    I would go with .45. I had my NGKs gapped at .40 in my old motor and it was cammed/tuned.
    I have also heard of the Bosch Platinums contacting the piston and closing up. Scary.
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    Quote Originally Posted by Z34LS1 View Post
    - - - Updated - - -
    Bosch plugs are crap. I have used them in the past and have never had a good experience with them. I use NGK Iridium plugs in my 2002 SS and I set mine at .045 and they work great.
    Indiana
    92 LS1 Lumina A4
    00 Formula WS9
    Thanks for the Heads up, I may be pulling them back out and increasing the gap.
    My Friend Tunes for Lingenfelter Performance Incorporated here locally, we'll see what he says tonight.
    I noticed Last night when cold my car ran a little rougher than before, once the ECM takes control it ran really good!
    I'd like to give a Shout out to Old #8..... F*@$ You you Bas$%#@@ Ass son of a Bit%^#^ my Popeye arms are all scratched up because of You!
    Indiana
    92 LS1 Lumina A4
    00 Formula WS9
    Got my 5.3 LSX in the avalanche a street tune, gonna do a mileage run tonight.
    The Lumina was having a problem connecting to the data cable to the PCM. We were able to record two data logs showing fuel curves and such but not able to save the current file or upload through the odb2 port. So my puter got yanked and taken to LPI to do the tune.
    Gonna be a couple days before I get it finished.
    We also talked about Gap. Brent has tuned and and ran the Dyno for over 10 years, he said the .005 difference is so minimal it wouldn't show up on the Dyno.
    Thanks for the Replies guys, .04 to .045 for Irradiums is perfect for stock to mild built motors, he said that on blown set ups they run a tighter gap because of air pressures.
    Member Redrokit8's Avatar
    Aug 2011
    Roseland NJ
    Pewter Silver
    2002 Trans AM WS6
    If I'm not mistaken, they come gaped at 45. Last time I used them every plug checked perfect right out of the box.
    Indiana
    92 LS1 Lumina A4
    00 Formula WS9
    Quote Originally Posted by Redrokit8 View Post
    Maybe Yours did but my brand new AC Delco's were set at .035 which baffled me.
    Waiting on the Tuner now so I fixed a lot of stuff:
    Leaky PCV Rubber had rotted, made new Aluminum Sleeve and lightly pressed the broken end into the aluminum sealed with light layer of RTV Black
    And being to tight for egr block offs I made these...
    Found this bad leaky hose way back on top by #7(Shown part way removed Dry Rotted and Cracked:
    Should be way better now..........
    Orlando, FL
    Mean Black
    Yeah I have to agree with OP on checking the gaps of brand new plugs. I had found some out of gap right out of the box.
    North Jersey
    2004 GTO M6
    By nature I have checked the gaps of plugs I installed in my previous cars.
    Pittsburgh
    2008 Hummer H3
    I use A/C irridiums in all my engines. Never an issue.
    .035 almost sounds like a 6cyl gap..
    Indiana
    92 LS1 Lumina A4
    00 Formula WS9
    I hear you, but it was a Sealed 8 pack...
    Indiana
    92 LS1 Lumina A4
    00 Formula WS9
    I read that these plugs should not be regapped, and if off return them for correct gap.
    I can see why but if you have a gapper that bends the contact back without touching the Irradium Tip I can't see why you can't change them. My gapper works this way . The ones that slide between them then twist could Definately break the Irradium.
    Pittsburgh
    2008 Hummer H3
    Same one I use, I regapped mine all the time never had any problems.
    Some sets have a spark patch added to the ground electrode and I could see where it could be damaged if not carefull.
    But as I was saying, if you're carefull and use the right gaping tool you'll be fine.
    Member bryceslu's Avatar
    Chicago, IL
    00 NHRA Formula
    The gaps would be different depending on what kind of plugs you are using. the .040 gap is for iridium plugs. Copper/platinum plugs would be a higher gap, I believe GM specced .060
    There was a GM service bulletin put out years ago when they switched over to iridium plugs.
    Indiana
    92 LS1 Lumina A4
    00 Formula WS9
    Quote Originally Posted by bryceslu View Post
    I posted the Bullitin above, unless there is an Upadate I believe it is .035
    Got my Long Tubes on, waiting for the exhaust shop to get an opening to make a new Y Pipe.
    Member herculesrider1's Avatar
    TX
    '00 TransAm RamAir WS6 M6
    When the GM service manual says "Do Not Change gap from .040", I think I would follow their advice!!!! I just called Advance Auto, and they can't even order the AC Delco 41-110 Iridium plugs. All they had was NGK, Denso, Bosch, Autolite. So I called a GM dealership and they had them in stock but wanted $9.36ea for them...MAN, they are proud of them aren't they???? Then I called AutoZone and they had them in stock and only wanted $6.99ea for the same plugs!!! Do your homework and you can save money!....
    Last edited by herculesrider1; 07-19-2013 at 02:33 PM. Reason: additional information on same subject
    I just swapped the plugs out in our Suburban -- the gap was already at .040" and that was the correct spec per the service manual. I did find that the plug number has been superseded from the number set forth in the service manual. Originally, these were 41-985's and are now 41-110's (exact same plug apparently). The stock plugs have 85,000 miles on them and actually looked about the same as the new ones from a wear perspective. Pretty amazing.
    TX
    I have heard that it is advisable to use anti-sieze on the plug threads and then dielectric grease on the coil/plug connections. Sounds like a good maintenance tip, but will the anti-sieze on the plug threads get down into the combustion chamber?
    North Jersey
    2004 GTO M6
    To be honest, I don't like anti-seize. Over time, that stuff solidifies and I have seen wheel studs lose threads from using it. But that's just me. I DO agree on the dialectric grease.
  1. Help: changing plugs, spark plug gap???
    By ggino85 in forum LT1
    Last Post: 09-21-2009, 10:25 AM
  2. What kind of oil 5w30& spark plugs&spark plug wire
    By ROMERO98Z28 in forum General Help
    Last Post: 09-01-2009, 01:50 PM
  3. Spark Plugs and Plug Wires???
    By CWW17 in forum External Engine
    Last Post: 10-22-2007, 03:27 PM
  4. Ac Delco Iridium Spark Plugs...
    By bolden3 in forum General Help
    Last Post: 08-25-2007, 08:05 AM
