11-24-2006, 03:30 PM #1
Taylor Thundervolt Plug Wires/ NGK TR55IX Iridium Spark Plugs
These have been installed for 45k miles with no sign of a problem. I will change the plugs at 50k - just because I think it is a good idea.
I will use the same kind of plugs again, if they are still out there, since the last set was so good.
Regards,
Darden02 NBM TA - Mecham New Version Hood/Wing, Jet Hot/Hooker Headers, ProDyno exh, Chrome ROH ZS, Volant, Corvette LS1 MAF, Hotchkis LCAs, STB & Adj. PHR, BMR SFCs, Global West Traclink, SLP Bilstiens, Firehawk springs, B&M Ripper, Moser 12 bolt w/ 4.10s, Eaton Posi, LS1 Edit, Hurst line lock- more.
12-22-2015, 09:46 AM #2
Update: Replaced my Taylor wires after 160,000 miles and they were used up. I suggest replacement at 150,000. Definitely got my money's worth out of these wires. Highly recommended. Replaced them with another set of Taylors.
12-23-2015, 03:29 AM #3
Never a bad idea to change out wear items like plugs and wires. Iridium plugs generally have a life span of 100,000 miles. I changed the iridium plugs in our Suburban at 90,000 miles and they showed no visible wear.
01-13-2016, 07:50 AM #4
I believe the Iridium plugs are good for 100k. Took mine out at 50k. No sign of wear.
I will replace them at 100k and put the old set back in for the other 50k they should be good for!
For Sale: Taylor Spark Plug Wires For LT1
By GOODZ/BADZ in forum Parts For Sale / TradeReplies: 4Last Post: 12-23-2008, 02:00 PM -
Spark Plugs and Plug Wires???
By CWW17 in forum External EngineReplies: 15Last Post: 10-22-2007, 03:27 PM -
NGK Iridium OR Ac Delco Iridium Spark Plugs..
By tyxpx in forum External EngineReplies: 44Last Post: 09-06-2007, 05:50 PM -
FS: Taylor Thundervolt wires
By MagicMan in forum Parts For Sale / TradeReplies: 2Last Post: 10-19-2006, 08:57 AM
