    Junior Member ff_jeff's Avatar
    stock c5 tranny power limit?
    Anyone know what the stock limits are? Can I put 10psi or HCI and headers on? or will I need a built tranny for that?
    BTW its an A4
    Corvette Moderator BlownC5's Avatar
    Essexville
    Jet Stream Blue
    2009 Lingenfelter ZR1
    I believe 500 rwhp is the usually the max. 10psi will put you around 550 or so but you MAY be ok. It really depends on how you drive it. Start hooking up and parts break.
    Every day is a gift-enjoy preston1980's Avatar
    Missouri
    Torch Red
    1999 Corvette Hardtop
    Quote Originally Posted by BlownC5 View Post
    I agree. The t56 seems to be a little stronger than the autos, but 500 horsepower seems to be a braking point from most of what Ive seen. Maybe 550 with a t56, but you need a better clutch when you get much past 400 or so. His being an auto, 10 psi will ruin his stock tranny, maybe not at first, but soon.
    Although if you run slicks, a tranny can go at any horsepower. among other things. Like you said, start hooking up and and parts break.
    were is a good place to buy a built c5 auto tranny?
    Junior Member Z06-Dave's Avatar
    PA
    Electron Blue
    2003 Z06
    Quote Originally Posted by ff_jeff View Post
    I don't know of a good place, but I do know the BEST...
    RPM TRansmissions
    I have been running their 4L60e level V with zero problems. I have over 100 nine and 10 second passes...
    I have well over 500HP
  1. Question: how fast can a stock ls1 tranny go
    By NavdeepWS6 in forum Manual Transmission
    Last Post: 12-09-2008, 06:07 AM
  2. stock speed limit ?
    By blindboy2k1 in forum Camaro / SS
    Last Post: 03-29-2008, 07:07 AM
  3. :help: how much power can A4 stock tranny take?
    By djvaly in forum Automatic Transmission
    Last Post: 03-08-2007, 12:15 PM
  4. tranny doesn't always hold power..
    By pr0zac in forum Automatic Transmission
    Last Post: 11-05-2006, 08:39 PM
  5. Stock LS1 shortblock power limit?
    By Roastem in forum Internal Engine
    Last Post: 01-12-2006, 11:39 AM
