Results 1 to 2 of 2
    Jun 2006
    new york
    96 vette
    tranny doesn't always hold power..
    if i go easy it works perfect and sometimes when i punch it it just takes off but sometimes in second gear it will slip under heavy throttle. and if i try to hold it out in first it will get 3/4 of the way reved out and it just kinda goes out of gear.. it takes a while to engage when you put it in drive.. i am guessing that the tranny is bad.. its a 94 t/a. the fluid was at the right level when i checked it.. don't know if there was a problem before i got it running.. i bought the car with a blown engine. i swapped the wiring harness and the speedometer started working..lol.. could it be something else besides the tranny needing replaced?
    Member ericwilloughby's Avatar
    Louisville KY
    Yellow
    2005 GTO
    Nope. If it has fluid and is still slipping. You need a trans.
  1. Power door lock doesn't work on drivers door..
    By 99RedTa6spd in forum Firebird / WS6
    Last Post: 09-03-2014, 08:20 AM
  2. Battery Hold Down - Hold Down Hold Up
    Last Post: 06-06-2013, 06:20 PM
  3. Guess she really doesn't hold ill feelings for him
    By GTP231 in forum Political / Debate Forum
    Last Post: 08-30-2012, 10:49 PM
  4. how much power can a 6spd hold?
    By 99blueZ in forum Manual Transmission
    Last Post: 08-10-2006, 11:53 PM
  5. How much power will the Rear end hold???
    By GOAT6SPD in forum GTO
    Last Post: 03-25-2006, 07:41 AM
