Results 1 to 20 of 24
    Member NavdeepWS6's Avatar
    Sacramento
    2002 Trans Am
    how fast can a stock ls1 tranny go
    Well i was wondering how fast can our stock tranny's really go up to with 3.42 rear gears if we had no governor on it and engine was capable with say a 800hp or more
    6 speed tranny just to let ya know
    180
    190
    200+
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    It would fry at 400 HP.
    Nuclear Cat Will End All LS1Powerhouse's Avatar
    Edwardsville, IL (So. IL Univ. of Edwardsville)
    Mystic Teal
    1999 Camaro Z28 - A4
    KFC style.
    Beaver Dam KY
    79 T/A -91 Firebird
    Mine fried with about 315
    Lets say you go all out... get a built level 3 4l60e. Might hold that much.. but if you have 800 hp you have the money to do a built 4l80e conversion.
    and that is where the fun is at.
    Senior Member
    rochester,ny
    pewter
    2001 z28 lingenfelter 383
    Quote Originally Posted by NavdeepWS6 View Post
    180
    190
    200+
    if your redline is raised like mine ( 6700) 190ish at redline in 5th.........in 6th its like 280 and ud need a few thousand hp
    Beaver Dam KY
    79 T/A -91 Firebird
    Anyone that is running that much HP(over 400 IMO) is running on borrowed time.
    Senior Member
    rochester,ny
    pewter
    the t-56 is made to handle much more than 400hp boys and the rear is only a problem when u beat on it........simply going fast isnt beating on it
    Beaver Dam KY
    79 T/A -91 Firebird
    Quote Originally Posted by tonyjnjz View Post
    Pretty sure it isnt MADE to handle but it can handle. I have seen in person 10 second 10 bolt cars. Same thing.
    Get a good rebuild with quality parts and dont ever worry again.
    Senior Member
    rochester,ny
    pewter
    what does 10 second cars have to do with top speed? NOTHING
    Beaver Dam KY
    79 T/A -91 Firebird
    First off, to pull in those upper gears requires horsepower. HP=More stress on the driveline. I was commenting on how the 10 bolts can hold a lot of HP and not break while some break on stock power.
    Upper gears in a STOCK tranny arent meant to handle that much HP.
    5th gear alone tops out at 181 MPH but I dont think any stock tranny has scene that.
    6th at 268 mph.
    kinda obvious.
    Senior Member
    rochester,ny
    pewter
    6th at 268 mph.
    kinda obvious.
    the c5 has the same tranny ( diff rear) and goes over 180.....next
    Beaver Dam KY
    79 T/A -91 Firebird
    Last time I checked the original poster has an 02 trans am. Totally different setup, I dont see any torque tube under my trans am. As well as no 10 bolt with a 3.42 gear setup on a c5...
    Do some research on the internals of a t-56 that was used on the F-BODIES.
    LS1 Performance Information > Vehicle Specific > Firebird / WS6
    Senior Member
    rochester,ny
    pewter
    my luos!!!! is your t-56 built with your emense hp in slowass???? has it self destructed yet and blew up at high speed?
    Stock 1999 T56.
    Still in one piece....although I do figure it is on borrowed time.
    And I don't do high speeds. 5th and 6th gear are not meant for WOT runs.
    Sacramento
    2002 Trans Am
    well i was just wondering how fast can i really go with a stock t-56 and where can i get a rebuild and i mean a badass rebuild with good stuff or just get a new -t56 or will a 2007 z06 tranny work with an ls1
    Beaver Dam KY
    79 T/A -91 Firebird
    Stock 1999 T56.
    See. I have read all over ls1.com/ls1tech lsall.com ls2.com, im 20 and i dont have kids. Readings is all i do
    and i listen w00t
    footbrake racer racer426's Avatar
    Jan 2008
    antioch,tn
    2004 gto
    get a 14 bolt rear with 4l80e .509cu bbc truck wha bah!!!!
    Senior Member
    rochester,ny
    pewter
    and i listen w00t
    he also runs it down the track with well over 500 rwhp .....the t56 is ment to take a pretty good beating
    Beaver Dam KY
    79 T/A -91 Firebird
    180
    190
    200+
    yep
  1. FAST 102/102 set-up on stock 346 cubes ?
    By LS1Mac in forum External Engine
    Last Post: 05-15-2010, 08:44 AM
  2. stock c5 tranny power limit?
    By ff_jeff in forum Corvette
    Last Post: 06-22-2009, 12:59 PM
  3. stock tranny mount movement
    By Poppn in forum Manual Transmission
    Last Post: 05-27-2008, 04:50 PM
  4. Porting fast with stock ls1?
    By LS1TOY in forum External Engine
    Last Post: 05-26-2008, 09:53 PM
  5. :help: how much power can A4 stock tranny take?
    By djvaly in forum Automatic Transmission
    Last Post: 03-08-2007, 12:15 PM
