Thread: stock tranny mount movement
05-18-2008, 01:58 PM #1
How much movement should the stock rubber tranny mount allow??
The stick vibrates a little at idle as usual, and under acceleration it moves upward about 1/2 an inch, maybe a little more.
I was thinking about going to poly mounts, but not sure if it's really necessary. Only mods are Magnaflow catback, SLP lid and K&N filter, and I don't have any other plans for it for awhile.
05-18-2008, 02:22 PM #2Member
- Oct 2006
- Springfield
Silver- 2004 SVT Cobra
Normal. The stock rubber mount has a lot of flex to it. If you put a poly in it everything will feel tighter, and as a trade off youll hear more noise from the tranmission.
05-27-2008, 04:15 PM #3
when a mount goes bad, does the tranny usually hit the tunnel under acceleration? my stick seems to move alot, but i don't hear the usual thud from the tranny moving. i guess i might just end up taking a look under the car. is it easy to spot a busted mount?
05-27-2008, 04:50 PM #4Member
- Oct 2006
- Springfield
Yes if when you shift you hear the transmission banging then it is torn. They are easy to spot once you get the mount out. Install university has a good write up for changing the tranny mount. The first time i changed mine out with a poly mount i returned it within a couple days, and used my 25 bucks towards another stock mount. Couldn't stand the noise. The stock mount cost me just under 90 bucks.
tranny mount
By 10xowner in forum General HelpReplies: 10Last Post: 12-28-2010, 09:54 AM -
Tranny Mount???
By redbird555 in forum Automatic TransmissionReplies: 5Last Post: 08-29-2009, 10:49 AM -
Bad tranny mount?
By Rhinohuey in forum Manual TransmissionReplies: 7Last Post: 07-27-2007, 04:57 PM -
Need a good T56 (LS1) Stock Tranny mount & Torque arm mount..
By 1slosnake in forum Parts Wanted / TradeReplies: 2Last Post: 06-19-2006, 03:04 PM -
By 1slosnake in forum Parts Wanted / TradeReplies: 1Last Post: 06-13-2006, 05:24 PM
