Results 1 to 1 of 1
06-14-2009, 05:15 AM #1Member
- Jan 2006
- houston
Navy Blue- ls1 trans am
creaking/ clicking? clutch pedal after cl install
Well after a success clutch install (thanks to the helpful input on this board and the help of a father in law thats a mechanic) the clutch pedal is doing something that it did before with my spec cltuch. I replaced the slave and bled the clutch with a mity vac. The clutch pedal does not go down smoothly, however it did go down smoothy after the install. It is about 1300 miles after install. It sounds as if its clicking a pittle while going down. I believe the pedla did this with the old clutch. My concern is that it is a bad master cylinder and I do not want this to damage my $600... labor intensive clutch. Doe anyone know what could cause this? Maybe air in the system still? Thanks guys
Clutch Pedal Pressure and Smelly Clutch
By race5050 in forum Manual TransmissionReplies: 1Last Post: 01-06-2010, 05:37 PM -
No pedal pressure after clutch install
By chevyss1234 in forum Manual TransmissionReplies: 7Last Post: 12-23-2009, 06:23 PM -
Clicking after LT install
By One_Bad_TA in forum External EngineReplies: 12Last Post: 06-04-2009, 11:54 PM -
Clicking when pedal pushed?
By PWNED in forum Manual TransmissionReplies: 1Last Post: 10-13-2008, 05:09 PM -
clutch clicking....
By ggino85 in forum Manual TransmissionReplies: 2Last Post: 07-28-2007, 01:58 PM
