    Junior Member silver99ss's Avatar
    Paducah Ky
    1998 C5 Corvette
    LS1 LS2 intake swap
    I was just wondering if the LS2 intake could be put on an LS1 motor? if it does work does it require any modification and where can I get a throttle body to fit it?
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    yes it will fit. you will need a 90mm TB. from what i've seen, people that have done it, got less than stellar performance over a FAST 90mm intake.
    Paducah Ky
    1998 C5 Corvette
    will the FAST 90mm TB for the ls1 bolt right on
    orlando, fl
    2014 camaro 2ss/rs
    not completely sure.
    Jun 2006
    FT. Bragg, NC
    Torch Red
    2000 Corvette
    the 90mm fast intake will bolt right on. the only problem is that there is some rewiring required for the ls2 throttle body. i am in the process of doing this on my 2000 C5, but for some reason im throwing codes related to the throttle by wire....ill keep you posted....
    Jun 2006
    modesto
    Bright Rally Red
    2000&2001 Camaro SS
    i heard the LS6 and the LS2 intakes put down the same numbers
    I'll have to dig through back issues but a mag I had did a dyno comparison and if I remember correctly the LS6 intake outperformed the LS2.
    Lost in Texas
    Custom Slate Blue
    99 B4C
    I've heard the same. I'd say the work probably isn't worth the payoff regardless.
    Senior Member ninobrn99's Avatar
    Aug 2003
    Honolulu HI
    all bore 370 Trans Am
    Yes, the ls2 intake can be put on, but the injector sizes are different. Typical LS1 injectors wont fit in the ls2 manifold. Also, on the ls2 vehicles, the wiring harness is different for the injectors. You will notice better performance from an ls6 than with the ls2 intake. If you want a 90mm setup and noticeable gains, then you're gonna have to pay to play and get the FAST setup.
    Nino
  1. Question: HOW TO: Swap stock intake with LS6 intake
    By thechad125 in forum General Help
    Last Post: 02-26-2013, 04:17 AM
  2. intake swap ?
    By jeffz0rz in forum External Engine
    Last Post: 10-05-2009, 05:01 PM
  3. ls6 intake swap
    By lonsr13 in forum General Help
    Last Post: 09-11-2008, 08:34 PM
  4. anyone ever get dtc after ls6 intake swap?
    By senicalj4579 in forum External Engine
    Last Post: 04-03-2007, 01:51 PM
  5. LS1 to LS6 intake swap.
    By gnomee in forum External Engine
    Last Post: 02-02-2006, 10:58 AM
