Thread: intake swap ?
10-01-2009, 07:26 PM #1
intake swap ?
i have a 5.3 in my gmc and am wondering the gains with a ls6 intake swap ? pros ? cons ?
10-01-2009, 07:45 PM #2
It would be interesting since you have a different looking manifold. A little more on the top end doesn't show any gains below 3500rpm compared to the ls1 manifold-then again different manifold. What size is your throttle body, and does it have 3 or 4 bolt holes? The ls-6 has 3
10-02-2009, 05:48 AM #3
not sure on TB size. everything is stock. my 5.3 is considered an ls motor isnt it ?
10-02-2009, 10:04 AM #4
10-02-2009, 12:25 PM #5
oh ok. so from swhat i'm reading some LS pars are compatible with my 5.3 ? are there stock ls parts that i can get for cheap that would bolt up and show some gains ?
10-03-2009, 05:36 PM #6Junior Member
- Oct 2009
- ontario canada
black- 2002 z71
bad new's
sorry but it's alot of work ls intake's won't clear truck accesory's that's why T/B is angled up have to try and switch to vette or f-body accesory's. i have heard of some company's makeing custom mounts for truck stuff
If speed kill's do brakes give life ?
10-03-2009, 07:17 PM #7Member
- Jun 2009
- coon rapids, MN
red- 2000TA
fast make a truck intake,heard it makes great power.
10-04-2009, 07:41 AM #8
any idea where i can find some go fast goodies for my 5.3 ?
10-05-2009, 04:01 PM #9Junior Member
- Oct 2009
- ontario canada
black- 2002 z71
i would recommend starting with the basics good cold air intake (airraid aem k'n) free flowing muffler (cheapest way to start is just cuting out the stock muffler and adding high flow one instead ) or cat back system programmer any of the big brands or custom then header's (long tube make better power but shorties are easy to install ) Comp makes cam's just for the truck motors the your budget is the limiting factor lots of superchargers available (magnuson, vortec ,procharger ) search on hear or gm-trucks .com
good luck
ps (with more power don't forget about upgrading the brakes ebc's are good)Last edited by canadaz71; 10-05-2009 at 04:05 PM. Reason: add signiture
Question: HOW TO: Swap stock intake with LS6 intake
By thechad125 in forum General HelpReplies: 18Last Post: 02-26-2013, 03:17 AM -
Question: Ls6 Intake swap
By Promise517 in forum External EngineReplies: 2Last Post: 05-25-2010, 07:50 AM -
ls6 intake swap
By lonsr13 in forum General HelpReplies: 2Last Post: 09-11-2008, 07:34 PM -
anyone ever get dtc after ls6 intake swap?
By senicalj4579 in forum External EngineReplies: 4Last Post: 04-03-2007, 12:51 PM -
LS1 to LS6 intake swap.
By gnomee in forum External EngineReplies: 3Last Post: 02-02-2006, 09:58 AM
