    incognito
    anyone ever get dtc after ls6 intake swap?
    i got p0121 after ls6 intake install. also the traction control off light stays on and when i put the car in drive it surges on and off meaning the idle is funky. i already know what this code means to a certain extent. anyone?
    01 SS A4 3.23-LID-CAI-LTS-ORY-CB-STALL-TUNED-326rwh,335rwt
    60'-1.666, 1/[email protected]
    doylestown, Pa
    SILVER
    2004 CTS-V
    DTC P0121 TP Sensor Circuit Insufficient Activity
    What else did you do besides install the intake?
    incognito
    I remover egr and air.
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    I just installed my LS6 intake this weekend. It was pretty straight forward, the worst part was unhooking everything from the back of the stock intake and getting all te harnesses/fuel rails out of the way.
    Only code I got is for the EGR, since it isn't hooked up.
    The DTC for P0121 is "Throttle Position Sensor A Circuit Range/Performance", so I would check to make sure you hooked the harness back up to the TPS. If it is hooked up, pull it apart, clean it with some MAF/electronics cleaner, and pt it back in. Maybe it just has a bad connection.
    incognito
    problem solved. these problems i was having was ALL because i rewired my map sensor wire harness wrong after i ripped it out on accident trying to take the intake out the 3rd fucking time It is confirmed, a messed up map sensor wire will set off a tps code.
  1. Question: HOW TO: Swap stock intake with LS6 intake
    By thechad125 in forum General Help
    Last Post: 02-26-2013, 03:17 AM
  2. Question: Ls6 Intake swap
    By Promise517 in forum External Engine
    Last Post: 05-25-2010, 07:50 AM
  3. intake swap ?
    By jeffz0rz in forum External Engine
    Last Post: 10-05-2009, 04:01 PM
  4. ls6 intake swap
    By lonsr13 in forum General Help
    Last Post: 09-11-2008, 07:34 PM
  5. LS1 to LS6 intake swap.
    By gnomee in forum External Engine
    Last Post: 02-02-2006, 09:58 AM
