Thread: LS1 Lifter vs LS7
06-05-2009, 11:07 AM #1Member
- Nov 2008
- Cheswick, PA
Silver- 1998 Camaro Z28
LS1 Lifter vs LS7
how can you tell the difference (visually) between the two?
also how can you tell if a lifter is bad when looking at it
I have bad lifters and I am buying a set of used LS7s (used on a dyno motor only) and i want to be sure i am buying what im being told im buying and that they are in good shape
thanks!
06-05-2009, 11:38 AM #2
06-05-2009, 04:17 PM #3
Shady.... I KNOW thats not YOUR hand!!!!!
dude!
The ls1 lifter part number is referenced as the LS7. It would be very hard to buy new actual LS1 lifters.
12-23-2009, 10:56 PM #4
BUT, remember to change to 7.350 pushrod length because the LS7 lifter is LONGER than the stock lifter......you will need to make up for this difference....
12-26-2009, 05:28 PM #5
12-26-2009, 07:35 PM #6
OK.......so the LS2/7 tray cup height is the difference????? OK, well that isn't the issue I was addressing...........My point was if one is re-using the LS1 cup with LS7 lifters. Many members state LS7 lifter in an LS1 cup have resulted in a shorter pushrod length (the most accurate being 7.35). In fact I confirmed this with Thunder Racing and Texas Speed, although measuring should always have the final say. So..........you may be right about YOUR statement, but I never involved the LS7 cup into the equation.....so your ia correct stuff isn't applicable in reference to the totality of MY statement. Thanks for the info though.......lol
01-04-2013, 08:05 PM #7
soooo any updates on this issue?
01-04-2013, 09:36 PM #8
01-05-2013, 01:48 PM #9Spaz is My Mentor
Wonder if this could be my problem?
I just did a LS7 lifter swap and swapped in CM 7.4" push rods because I was told the length would not change with the new lifter.
01-05-2013, 02:32 PM #10Senior Member
- Apr 2010
- Alabama
1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
01-05-2013, 02:40 PM #11Spaz is My Mentor
I wonder if the difference between the length has to do with which heads you have. The 98's have 8?? (something) while the later yrs use 241's.
I just ordered a PR checker form ws6store. ($20 in case any one wants to know)
I hope this is what my issue is. I just don't want to tear a block out and find out it's for something like this.
01-05-2013, 02:42 PM #12
WTD: 1 LS1 lifter
By rll2 in forum Parts Wanted / TradeReplies: 1Last Post: 09-21-2009, 02:31 PM -
Bad lifter
By bigrondownhiller in forum Internal EngineReplies: 7Last Post: 07-26-2009, 04:14 PM -
lifter tap?
By mach1mike in forum Firebird / WS6Replies: 6Last Post: 03-03-2009, 04:11 PM -
lifter tap?
By mach1mike in forum Internal EngineReplies: 3Last Post: 03-01-2009, 05:26 PM -
Pontiac Lifter Guide - Lifter Lowdown
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 10-09-2008, 06:10 AM
