Thread: lifter tap?
03-01-2009, 11:19 AM #1Junior Member
- texas
black- 2000 Trans Am
lifter tap?
after some research i finally came to the conclusion i have a bad lifter. what are some good suggestions on what to replace them with? Im thinking of going with ls7 lifters. Also is it safe to drive for a week or so with this? it just started yesterday btw.
03-01-2009, 03:35 PM #2
Did you pull the rockers and pushrods to inspect them ? One may be bent...
03-01-2009, 03:48 PM #3Junior Member
- texas
no i didnt car will be checked this week.
03-01-2009, 05:26 PM #4
It's a lot more work to get to the lifters... Gotta pull the heads. I'm running the comp cam 850's in mine and I heard the LS7 is a good upgrade too. If you're high milage, and a lifter is collapsed, I would also change the O-ring on the oil pump pick up tube. It can be done through the front cover.
LS1 Lifter vs LS7
By Camaro98Z/28 in forum General HelpReplies: 11Last Post: 01-05-2013, 02:42 PM -
WTD: 1 LS1 lifter
By rll2 in forum Parts Wanted / TradeReplies: 1Last Post: 09-21-2009, 02:31 PM -
Bad lifter
By bigrondownhiller in forum Internal EngineReplies: 7Last Post: 07-26-2009, 04:14 PM -
lifter tap?
By mach1mike in forum Firebird / WS6Replies: 6Last Post: 03-03-2009, 04:11 PM -
Pontiac Lifter Guide - Lifter Lowdown
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 10-09-2008, 06:10 AM
