Thread: lifter tap?
    texas
    2000 Trans Am
    lifter tap?
    i have a lifter tap on my car i believe after doing some research is it safe you still drive the car. It just started yesterday.
    you'll want to fix it. If you have any mechanical skills (and a torque wrench) I suggest going at it yourself b/c there's a lot of work involved.
    Member side2000's Avatar
    md
    2000 camaro ss
    its safe to drive it home to then work on it. . . .not the best idea to drive for long because a collapsed lifter can bend pushrods among other unfriendly things.
    texas
    2000 Trans Am
    i wont be able to work on it for 2 weeks but im going to replace the lifters, push rods. Anything recommended? i think im going to go with ls7 lifters. i dont know about the rods.
    md
    2000 camaro ss
    i wouldn't really drive around with it for 2 weeks. you can just do lifters while youre in there as long as your pushrods arent bent. pushrods are cheap so if you have the money its certainly a might as well, especially if you plan on doing a cam swap later on.
    Ohio
    98 T/A
    i know this will sound crazy 1 qt kerosene in with the oil run for 5 min then drain put new oil in and bottle of lucas that shit works
    Pittsburgh
    2008 Hummer H3
    Thumbs up
    Quote Originally Posted by 69camaroandmore View Post
    Not crazy that "motor flush" crap is essentially kerosene. Just do'nt drive it with any of these in the crankcase. But you all prolly know that.
  1. LS1 Lifter vs LS7
    By Camaro98Z/28 in forum General Help
    Last Post: 01-05-2013, 03:42 PM
  2. WTD: 1 LS1 lifter
    By rll2 in forum Parts Wanted / Trade
    Last Post: 09-21-2009, 03:31 PM
  3. Bad lifter
    By bigrondownhiller in forum Internal Engine
    Last Post: 07-26-2009, 05:14 PM
  4. lifter tap?
    By mach1mike in forum Internal Engine
    Last Post: 03-01-2009, 06:26 PM
  5. Pontiac Lifter Guide - Lifter Lowdown
    Last Post: 10-09-2008, 07:10 AM
