    GET SOME claytonr's Avatar
    San Antonio, Texas
    Pewter Metallic
    2002 Pontiac Trans AM
    Replacing AC high pressure hoses
    my lower hose has a hole rubbed in it...its the hose from the condensor to the compressor? after i put it on with the system need to be vacuumed or can i just put freon in?? i priced the assembly at 120 dollars does that sound about right?
    Arizona
    I always suck the system down when ever I open it. It's best to see if the system will hold a vacuum before you shoot your freon/oil in.
    Otherwise you could be wasting your new freon ,,,,if there is a leak.
    Single Malt rbob93's Avatar
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    $70 + shipping from www.rockauto.com
    Vacuum it out.....do it right or not at all.....or replace the hose & have a shop do it for you
    Did mine last year about this same time.....lots of fun!
    San Antonio, Texas
    Pewter Metallic
    anyone got a part number..there is two sets of hoses for sale..i researched it but the pics do no justice for me because i have not taken it off therefore i dont know what it looks quite like..lol..it is on passenger side coming from condenser to compressor it starts off rubber then goes to metal before it curves up somewhere and attaches to the compressor..i dont have a lift where i live here so i only wanna jack it all up once to take it off!
    this one?
    http://198.208.187.182/internet/Part...rtnbr=15-31009
    or this one?
    http://info.rockauto.com/FourSeasons...html?56650.jpg
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    Those pics are both the same hose.....Top one is genuine.....bottom is not
    AC Delco part# 15-31009 replaces part# 10409630
    After you get the hose, study the routing carefully!
    Jack it up so you can see from underneath.....might even want to take pics
    Also, make sure you don't have any contact with the waterpump pully with the new one
    I found it easier to drop the compressor start the bolt on the back
  1. high volume / high pressure pump ?
    By seweber in forum General Help
    Last Post: 11-11-2011, 04:09 PM
  2. Performance Fuel Hoses - When Good Hoses Go Bad
    Last Post: 12-02-2010, 07:10 PM
  3. Question: Can Oil Pressure be too high?
    By jrc1122 in forum General Help
    Last Post: 03-13-2008, 07:36 PM
  4. high oil pressure c5?
    By NIKDSC5 in forum Corvette
    Last Post: 06-12-2007, 02:07 PM
  5. Replies: 3
    Last Post: 01-27-2007, 12:05 PM
