Thread: Pushrod length?
    Apr 2009
    Centerton AR.
    2001 Firebird Trans Am
    Pushrod length?
    I have the PRC 2.5 5.3L heads for my 01 LS1 and I already have Alum. 1.7 roller rockers for them, I also have the MS3 cam. Should I buy the stock length 7.4 pushrods? Im not changing the stroke or bore.
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    Heads been milled?
    You should ALWAYS test it with a head swap.
    Lowered, HID's, tinted.
    mercersburg pa
    hugger orange
    2004
    call up summit or jegs and buy a pushrod lenght checker....they are pretty cheap and can save lots of headaches
    Apr 2009
    Centerton AR.
    I guess i dont understand why I need a pushrod checker, I know they are only 15-20 bucks but if i didnt change the ratio of the rockers and the lifters are going to be the same as the stock ones, shouldnt the pushrod length be stock 7.4?
    mercersburg pa
    hugger orange
    2004
    Quote Originally Posted by 2001TransAm View Post
    should be, but its just a step to be sure.
    my cam called for longr pushrods, but after checking I still had to use stock lenght pushrods.....so you never know till you check
    Trolling Live Chat
    Bellevue, NE
    01 Trans Am
    yeah man, it's better to be safe than sorry when it comes to the pushrods. My PRC 215's aer alot taller than the stock heads. Needed a 7.5 PR.
    Apr 2009
    Centerton AR.
    Thanks guys.
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    bore and stroke, rockers arms, or lifters do not matter, when it comes to the length of the pushrods. in a non adjustable valvetrain, what matters is the deck height of the heads and block, camshaft base circle, and head gasket thickness. are you using a thinner head gasket? how much was cut off the heads? was the block decked? anytime you change these areas, you are changing the total distance from the lifter to the rocker.
    milling the heads, milling the block, and using thinner head gaskets bring the valvetrain closer to the cam. in a non-adjustable valvetrain, you will need shorter pushrods to compensate for this. if you know how much was cut off the heads, block, and how much thinner the head gasket is from stock, then you just shorten the pushrod that much. if not, then you'll need a checker.
    Senior Member Hurley711's Avatar
    Earth
    414 RWHP 395 RWTQ
    00 Black Ram Air Trans Am
    $20 is worth the headache saved if you put in the wrong length
    mercersburg pa
    hugger orange
    2004
    well said, (i should have milled them the last time i had them off) but right now i'm just on the loose side of clearance with my cam swap, after i mill mine it should put me right where i should be
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    Yea buy it now and you will never be asking this question again. Tools make the world go round
  1. pushrod length?
    By Edward-T in forum Internal Engine
    Last Post: 10-21-2011, 04:36 AM
  2. pushrod length??
    By Mikat1 in forum Internal Engine
    Last Post: 03-15-2011, 09:36 AM
  3. need help with pushrod length
    By SexyTransAm in forum Classic Muscle
    Last Post: 01-15-2008, 03:50 PM
  4. Pushrod Length?
    By Pickupman404 in forum Internal Engine
    Last Post: 03-02-2007, 05:43 PM
  5. pushrod length help
    By laststaric in forum Internal Engine
    Last Post: 07-19-2006, 05:26 PM
