Results 1 to 2 of 2
    09 G8 GT
    Question Clutch fluid changing
    I searched for "hydraulic clutch fluid" and found a thread from '05, just figured I'd start a new one instead of posting in almost a 4yr old discussion. 04 w/ 57,000 miles, was spraying some silicone grease on the hood latch this afternoon and decided to take the cap off the clutch fluid reservoir-its almost BLACK, albeit still full. Clutch seems to work fine-now I read the TSB on this that says "do not replace fluid" but, that can't be GOOD can it? Can I change it out myself(difficulty-wise...I'd consider myself "mechanically inclined" but never bled brakes or a clutch system before) Replacement fluid is DOT-3 brake right? thanks for any info..
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Quote Originally Posted by ls1fan74 View Post
    DOT-4. I use the "turkey baster" method and suck out the black fluid and refill with fresh fluid.
  1. Changing diff fluid..
    By ls1fan74 in forum GTO
    Last Post: 09-03-2009, 09:10 AM
  2. Changing trans fluid and rear end fluid
    By 98Z28importslayer in forum Drivetrain
    Last Post: 07-29-2008, 08:33 AM
  3. Changing own Trans Fluid?
    By Patsy57 in forum Manual Transmission
    Last Post: 04-11-2008, 02:58 PM
  4. Changing the Brake Fluid
    By StylesMcKnob in forum General Help
    Last Post: 06-19-2007, 07:36 PM
  5. Changing tranny fluid.
    By yellowv in forum Manual Transmission
    Last Post: 02-17-2007, 09:11 AM
