Thread: Changing the Brake Fluid
06-18-2007, 11:26 AM #1Its the Hotwad
- Apr 2007
- Twentynine Palms, CA
Pewter- 2000 Formula 6spd
I need help. Ive never changed the brake fluid in my car but it seems pretty straight foward. So what do I do? I'm going out later to buy a Haynes Repair Manual so I'll find out but I wanna hear it from you guys. You just take off the lines and drain them? Also what kind of lubricant should I buy? I dont know so any help is greatly appreciate it I just wanna hear what you guys have to say about it. Thanks
06-18-2007, 12:10 PM #2Slow'er'Ass
- Thornton, CO
I use a synthetic DOT4 fluid.
Prestone I think. Buy a big bottle ($6-7).
Upcap the master and use suction to remove about half of the fluid.
Then start bleeding them. Make sure you keep a very close eye on the master fluid level. Once it gets pretty low (Don't let it run dry) fill with new fluid.
Continue bleeding each corner until you see new fresh fluid come out at each corner. Always check your master fluid level and keep it full while bleeding.
Bleed in this order...
Passenger rear
Driver rear
Passenger front
Driver front
06-19-2007, 10:36 AM #3Its the Hotwad
- Apr 2007
What do you mean by use suction? do you mean pressing the pedal or what?
06-19-2007, 02:30 PM #4
he was refering to something like a vacuum device. if you don't have one, then just start bleeding the brakes. once the master cylinder is close to empty, then add more into it. keeping bleeding the system until the fluid goes from a dark color to a light color.
06-19-2007, 02:32 PM #5
06-19-2007, 07:36 PM #6
changing trans fluid???
By twozs in forum Automatic TransmissionReplies: 18Last Post: 08-19-2010, 10:22 AM -
Clutch fluid changing
By ls1fan74 in forum GTOReplies: 1Last Post: 04-24-2009, 05:44 PM -
Changing trans fluid and rear end fluid
By 98Z28importslayer in forum DrivetrainReplies: 6Last Post: 07-29-2008, 08:33 AM -
Changing own Trans Fluid?
By Patsy57 in forum Manual TransmissionReplies: 7Last Post: 04-11-2008, 02:58 PM -
Changing tranny fluid.
By yellowv in forum Manual TransmissionReplies: 3Last Post: 02-17-2007, 09:11 AM
