Results 1 to 20 of 38
Thread: Changing diff fluid..
06-13-2009, 04:26 PM #1Member
- Oct 2005
White- 09 G8 GT
Anyone have a how-to on this? Sorry if it seems like a newb question but I searched and found some threads on "what fluid to use" but not actually HOW to do it.......it's prob ridiculously easy for most of you but this is my first RWD car and I haven't done one before.
06-13-2009, 06:17 PM #2
06-13-2009, 07:20 PM #311 years of bangin gears
- Jan 2009
- North Jersey
I changed over to AMSoil 75-140 Severe Gear and was good but a few days later my diff developed a low-speed chatter. I bought a tube of CRC True Gear diff additive and the chatter is gone now. Feels alot better.
06-13-2009, 07:22 PM #4Member
- Oct 2005
White- 09 G8 GT
30 mm? day-um thats a big one....ok so that's it? 15 mm open and let it drain out, then plug it back up and open the 30 mm, add 3 quarts of 75w-90? I'm upstate ny...its pretty warm right now, I'm stock and drive fairly agressive not too bad though. Should I go heavier? (80w140?)
06-14-2009, 03:03 AM #5
Chatter
75W-110, or 75W-140 is a better rout to go as some have differential chatter issues with the 75W-90; a little too thin in some applications. Also, AMSOIL Severe Gear already has limited slip additives in it, but some do end up needing more. AMSOIL Slip Lock⢠Differential Additive is compatible with the other additives in Severe Gear.
CompSyn
06-14-2009, 03:19 AM #6Grand Imperial Wizard
- Retired Outlaw Sum Bitch
Let me find a pic of my diff and I'll do a quick write up with some arrows for you....
06-14-2009, 03:21 AM #7Grand Imperial Wizard
Hells bells...Ol RedGTO beat me to it....
http://www.redgto.com/KB/article.asp...7&cNode=5U4I3A
06-14-2009, 10:13 AM #8Member
- Oct 2005
White- 09 G8 GT
that.is.awesome. thanks a bunch thats a huge help..i may do the trans fluid now too
07-03-2009, 11:28 AM #9Member
- Oct 2005
White- 09 G8 GT
can i get this friction modifier from the dealer?
07-03-2009, 12:03 PM #10James Bond
- Aug 2007
- Texas
I was gonna help but your rear end is way different than mine. I have one plug, on the side of the housing, above the axle. Only way to drain is to either pump it out, or pop the diff cover.
07-04-2009, 06:15 AM #11Member
- Oct 2005
White- 09 G8 GT
No prob....I think I'm gonna go with mobil 1 from the auto parts store and that trans-x friction modifier....I'll leave it in for a bit, if i start to hear noise (theres none now...purely maintenance) I'll order some amsoil.
07-05-2009, 04:29 PM #12
ls1, Got mine at the dealer ship it is P# 43161, but make sure the bottle inside the wraper has 7089 on it. I used RP and really didn't have to use any but just for insurance used 1/2 oz. Just to let you know it smells like hell and use rubber gloves. Jack
07-05-2009, 05:40 PM #13Grand Imperial Wizard
No shit...I think we should drop about 4 oz of that shit on them towel head sons bitches...they quit right there and join the Catholic Church....man that stuff STINKS!
07-05-2009, 06:12 PM #14
It's freaking nasty shit!!!
07-06-2009, 04:59 AM #15Member
- Oct 2005
White- 09 G8 GT
umm is there any downside to too MUCH friction modifier? if there is such a thing?
07-06-2009, 10:49 AM #16Grand Imperial Wizard
The modifier makes your lube less slick so your diff will engage in lockup (posi traction) so you are diluting your lubes ability to be slick....
07-06-2009, 06:38 PM #17
Dealership prices on the lube is way expensive. Evn the parts guy told me to go buy it from Chinazone,
And yes, it stinks badly. I honestly wear gloves anymore. Hate that smell.
07-08-2009, 02:29 AM #18Member
- Oct 2005
White- 09 G8 GT
yea i ended up spilling some on my hands as well as the tarp i'd put down to work. then i rolled onto it, so it got my shirt too. I put about i'd say 4-5 oz of trans-x in before I filled the diff..too much? should I change it again?
07-08-2009, 09:07 AM #19Member
- Mar 2009
- indianapolis
PBM 366ci TC78 E85- 2004 Pontiac GTO PBM A4
i used 75w 140 ROYAL PURPLE, it already had the friction modifier in it. and i used two quarts, gm said to fill it to the bottom of the fill whole. lol you cant fill it more then that. lol. i think my diff is alot smoother now with the RP. nice stuff.
07-08-2009, 10:32 AM #20Member
- Feb 2008
- NEW JERSEY
PEWTER- 2001 TRANS AM WS6
RP you should just pee in your rear you will get the same effect
Diff Fluid
By Sarge in forum GTOReplies: 42Last Post: 06-10-2011, 08:38 PM -
Best Oil, Filter, and Diff Fluid
By Intrepidman in forum General HelpReplies: 28Last Post: 10-08-2008, 11:02 AM -
Changing trans fluid and rear end fluid
By 98Z28importslayer in forum DrivetrainReplies: 6Last Post: 07-29-2008, 08:33 AM -
diff. fluid/ additive
By imflyn in forum DrivetrainReplies: 5Last Post: 11-02-2006, 10:54 AM -
best diff fluid? good diff cover?
By ErikElvis in forum Camaro / SSReplies: 3Last Post: 03-23-2006, 08:49 PM
