Results 1 to 20 of 43
Thread: Diff Fluid
02-28-2009, 02:48 PM #1Grand Imperial Wizard
- Retired Outlaw Sum Bitch
Diff Fluid
Just flushed and filled the diff....RedLine 75-140....all the years I been dicking with cars I still am not use to the stink of diff fluid....man that shit stinks....
02-28-2009, 03:57 PM #2
02-28-2009, 06:15 PM #3
I'm using Torco RGO Racing Gear Oil (85-140)
02-28-2009, 06:18 PM #411 years of bangin gears
- Jan 2009
- North Jersey
02-28-2009, 06:39 PM #5
02-28-2009, 06:42 PM #6
It smells like rotton eggs every time I walk out into my garage. I have a small leak coming out from the front of my ten bolt and there's always a few drops sitting under my car. Shitty smell never goes away.
02-28-2009, 06:42 PM #711 years of bangin gears
- Jan 2009
- North Jersey
Gotcha. I gotta get that stuff. I think when the previous owner replaced the diff he overfilled it cuz I have a leak from the top of the diff. I read on the GTO forum that when the diff is overfilled, it sprays out from the vent and onto the exhaust. FUKKEN STINX!!!
03-01-2009, 03:18 AM #8Grand Imperial Wizard
How do you overfill a diff? I mean you fill it up until it runs out the hole.....
03-01-2009, 03:24 AM #9Grand Imperial Wizard
Well the Torco ( conventional oil base) does have a thicker than normal film strength.....and this is why folks over at ls1gto "think" it is better cuz it quietens their rear gears.....but the truth of the matter is quiet is not always better.....Torco has crap add packs for friction modifiers/foam prevenitives/seal conditioners...and frankly Shell Rotella 85-140 at WalMart returns better gear wear numbers than that Torco garbage....
But the dipshits at ls1gto.com go by their butt dynos and sing Torco's praises.....let em go right ahead...but I prefer data and a return on my investment in lubrication/heat control/long term protection of a quality diff lube like Royal Purple/RedLine/Amsoil all three returning excellent wear numbers....and Oh shock...all three do not require friction modifiers.....this should be a big indicator guys.....
And yes I have ran and tested Torco against all three mentioned above.....
03-01-2009, 03:56 AM #10Grand Imperial Wizard
Here is the VOA of Torco...
ALUMINUM:0
CHROMIUM:0
IRON:0
COPPER:0
LEAD:0
TIN:0
MOLYBDENUM:143
NICKEL:0
SILVER:0
TITANIUM:0
POTASSIUM:0
BORON:4
SILICON:8
SODIUM:0
CALCIUM:1390
MAGNESIUM:11
PHOSPHORUS:754
ZINC:916
BARIUM:0
Weak is an understatement....
03-01-2009, 04:08 AM #11Grand Imperial Wizard
Torco...
SAE Grade ASTM# ........ 80W-90..... 85W-140 ...... 250
Appearance Visual ........ Amber........ Amber....... Amber
Viscosity @ 100°C D-445 20.23 ........ 34.42 ...... 42.69
Viscosity @ 40°C D-445 181.75 ....... 367.94 ..... 490.23
Pour Point, °C D-97 -25 -20 n/a
Flash Point, °C D-92 218 230 243
Amsoil..........75-140
Kinematic Viscosity @ 100°C, cSt (ASTM D-445) 25.7
Kinematic Viscosity @ 40°C, cst (ASTM D-445) 194.3
Pour Point, °C (°F) (ASTM D-97)......................-48 (-54)
See how thick that crap is!
Thick does not equate to lubrication guys.....
03-01-2009, 04:16 AM #12Grand Imperial Wizard
Good read by independent study......Look how ls1gto favorite gear lube does....
http://www.amsoil.com/products/gearl...hitePaper.aspx
03-01-2009, 05:14 AM #13Senior Member
- Mar 2008
- OHIO"S only 9 second GTO
Phantom Black Metalic- 2005 GTO
Interesting,I have never tryed the high dollar shit,thought it was a bunch of hype,Ive always used autoparts brand the kind that came with the modifyer in them and always syn.I dont know shit about all the chemistry studys nor do I want to take the time,Id say if sarge says the shit is good well thats good enough for me.maybe next time I do mine ill go to the Amesoil,so where the best place to get it?I also plan on doing the new built motor in the next few weeks,so might as well try it...
03-01-2009, 05:23 AM #14Grand Imperial Wizard
Well I appreciate your trust in me and I do work/read/listen and test all these lubes prior to commenting at all.....I do not care who is hitting who with dipsticks JIMMY...nor do I give a piss about any dyno runs showing HP gains.....I do not take it lightly that people do read my post and I feel a responsibility for sure....
With that said.....often times the higher end stuff is really no better than the lower cost solutions....Royal Purple is a prime example of this in their motor oils.....I would run Yellow Bottle Pennzoil at $2.50 per quart and get better results for my Oil Change Intervals than with $9 a quart Royal Purple garbage.....and have....and have the UOA's to prove my statements......
CompSyn is a great guy and works hard for our members....buy any Amsoil products through him.... http://www.competitionsynthetics.com/
Always reference code#ZO#1606470 when you place an order either by phone or online as CompSyn gets credit for your purchase.....
03-01-2009, 05:59 AM #15Grand Imperial Wizard
I would also submit the choice of diff fluid has a direct impact on breaking stub axles.
Go over to DoricandHRJlikethecock.com and tell me what diff fluid folks were running when they broke a stub.
Heat plays a major role in breaking a stub. Higher heat over time will make it brittle and that sum bitch will break of right at the point the splines start....this is heat related as much as torque related....
Just spend a few minutes and go do a little research......come back and tell me what gear oil they were running......
Most will be Royal Purple or Torco......now I'll take RP over Torco any old day....but Amsoil and RedLine run significantly cooler than the above mention two oils....
and say hi to Doric and HRJ for me....dont expect either one to reply as they probably have a dick in their mouths....
03-01-2009, 09:33 AM #1611 years of bangin gears
- Jan 2009
- North Jersey
So I should use the Rotella 85-140 then? My job uses Rotella T for diesel oil changes and the customers don't complain.
03-01-2009, 10:49 AM #17Grand Imperial Wizard
Better than Torco for sure....
03-01-2009, 11:40 AM #1811 years of bangin gears
- Jan 2009
- North Jersey
OK. Gonna give my job's parts supplier a call. We use the Rotella so if I don't need the friction mod then I'm good to go.
03-01-2009, 02:01 PM #19Grand Imperial Wizard
I'd have a bottle of this just in case with the Rotella....you may not need it but better safe than sorry....it is cheap.....
http://www.amsoil.com/storefront/ada.aspx
You wouldn't need it with Amsoil/RedLine or Royal Purple...
03-01-2009, 02:07 PM #2011 years of bangin gears
- Jan 2009
- North Jersey
OK. We use AMSoil at my job too. I gotta read the bottle of I think it's called "SEVERE GEAR" oil. Never seen that stuff before.
Changing diff fluid..
By ls1fan74 in forum GTOReplies: 37Last Post: 09-03-2009, 09:10 AM -
rear diff. fluid change
By z28_81 in forum DrivetrainReplies: 3Last Post: 06-06-2009, 10:37 AM -
Best Oil, Filter, and Diff Fluid
By Intrepidman in forum General HelpReplies: 28Last Post: 10-08-2008, 11:02 AM -
diff. fluid/ additive
By imflyn in forum DrivetrainReplies: 5Last Post: 11-02-2006, 10:54 AM -
best diff fluid? good diff cover?
By ErikElvis in forum Camaro / SSReplies: 3Last Post: 03-23-2006, 08:49 PM
