Results 1 to 1 of 1
04-03-2009, 02:50 PM #1Blown, Stroked, & Sprayed
- Aug 1999
- No Where
358 Small Block Cylinder Head & Rocker Arm Upgrade
358 Small Block Cylinder Head & Rocker Arm Upgrade - A Different World
We tear the heads out of a 1970 Chevy Chevelle and replace them with World Products Motown 235CC cylinder heads and Scorpion 1.6 rocker arms for more horsepower and torque.Gaining more power from a proven combination can be tricky. It's easy to do too much, forgetting that "bigger is better" isn't always true.In this case, we were looking to extract more power-and faster e.t.'s-from the 11:1, 358ci solid flat-tappet small-block in Matt Daeseleer's '70 Chevelle. The car had a best run of 12.68 at 110 mph going into the project, so it was no slouch, and we certainly didn't want to mess up a good thing. Fortunately for all involved, we didn't. Moving more air through this motor with a set of big, 235cc runner Motown 23-degree cylinder heads, teamed with a bump in cam specs via a set of Scorpion 1.6:1 rocker arms, proved to be exactly a formula our test subject liked-especially at the track.
Photo Gallery: 358 Small Block Cylinder Head & Rocker Arm Upgrade - Chevy High Performance Magazine
More...
More Than You Need to Know About Small-Block Ford Rocker Arm
By Ed Blown Vert in forum General HelpReplies: 0Last Post: 10-18-2012, 07:30 PM -
Trick Flow Cylinder Head Upgrade For 2 Valve 4.6L
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 05-18-2010, 02:50 AM -
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 05-11-2010, 01:10 AM -
Oval Port Small Block Cylinder Heads - Little Pack
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 12-04-2009, 08:10 PM -
Texas Speed LS1 Cylinder Head Upgrade, Part 1 - Bi
By Ed Blown Vert in forum GTOReplies: 2Last Post: 11-08-2008, 09:25 AM
