Results 1 to 1 of 1
12-04-2009, 08:10 PM #1Blown, Stroked, & Sprayed
- Aug 1999
- No Where
Oval Port Small Block Cylinder Heads - Little Pack
Oval Port Small Block Cylinder Heads - Little Package, Big Hero
Cylinder head technology is an ever-growing evolution and these days, conventional 23 degree heads have never been better.Cylinder head technology is an ever-growing evolution and these days, conventional 23 degree heads have never been better. Some say the incredible advancement comes from the needs of drag racers, who subject themselves into stringent classes requiring conventional heads. This may or may not be true, but whatever the case, cylinder heads are significantly better from what was available in the past.inline_mediumwraptextrightSprings
The standard spring package has a 1.950-inch installed height and comes with a 1.550-inch diameter roller setup that's good for up to 0.700-inch lift with seat pressures at 240 lb closed and 550 lb open. Optional springs that can handle up to 0.750-inch are also available or Brodix can assemble the heads with springs supplied by the end user.
Rocker Mount
Conventional roller rockers will easily bolt on, however for all-out performance applications, it's highly recommended to upgrade to a shaft-mount system.
Ports
Every 229 features a full intake and exhaust CNC port.27388102/tech/engines_drivetrain/cams_heads_valvetrain/1001chp_oval_port_small_block_cylinder_heads1001ch p_01_z+brodix+oval_port_229_cylinder_heads.jpgTrue
Photo Gallery: Oval Port Small Block Cylinder Heads - Chevy High Performance Magazine
More...
Edelbrock Performer Pontiac Aluminum D-Port Cylinder Heads -
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 04-25-2013, 05:40 PM -
LS3/L92 Rectangle-Port Cylinder Heads Test - The Even More U
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 01-07-2011, 02:40 PM -
D-Port Cylinder Heads - D-Port Development
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 12-14-2010, 08:30 PM -
358 Small Block Cylinder Head & Rocker Arm Upgrade
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 04-03-2009, 02:50 PM
