Results 1 to 1 of 1
05-11-2010, 01:10 AM #1Blown, Stroked, & Sprayed
- Aug 1999
- No Where
Trick Flow Cylinder Head Upgrade For 2 Valve 4.6L
Trick Flow Cylinder Head Upgrade For 2 Valve 4.6L Ford Modular Engines - 453HP 2V 4.6 - Speed Parts Testing
When we first had the idea of building a Junkyard Jewel out of Ford's much beleaguered but widely produced 2V 4.6L (Apr. '08), we knew our biggest stumbling block was going to be the heads.When we first had the idea of building a Junkyard Jewel out of Ford's much beleaguered but widely produced 2V 4.6L (Apr. '08), we knew our biggest stumbling block was going to be the heads. Even with 46mm oversized valves in '99-and-later Power Improvement (PI) heads and the most extensive porting magic Ford Performance Solutions could work, we were still barely cracking 200 cfm of airflow. While that was a significant improvement over stock, it was nowhere near the breathing room we wanted for our small-displacement, SOHC engine. Wehn we first built our 4.6 there were no aftermarket heads available. That has changed, thanks to Trick Flow Specialties (TFS).inline_mediumwraptextright00Finally, an aftermarket cylinder head for Ford's two-valve modular motor.29138491/techarticles/engine/hrdp_1006_trick_flow_cylinder_head_upgrade_for_2_v alve_46_l_ford_modular_engineshrdp_1006_01_o+trick _flow+46l_cylinder_heads.jpgtrue
Photo Gallery: Trick Flow Cylinder Head Upgrade For 2 Valve 4.6L Ford Modular Engines - Hot Rod Magazine
More...
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 05-18-2010, 03:00 AM -
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 05-18-2010, 02:50 AM -
Trick Flow Cylinder Head Insight - CHP Insider
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 08-21-2009, 10:00 PM -
(1) REPAIRED 215CC Trick Flow cylinder head GenX C
By 9t8z28 in forum Parts For Sale / TradeReplies: 15Last Post: 02-18-2009, 05:45 AM -
High-Flow Pontiac Cylinder Head Packages - Cylinder Head Symphony
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 01-16-2008, 04:40 PM
