Results 1 to 16 of 16
    doylestown, Pa
    17 (100%)
    SILVER
    2004 CTS-V
    (1) REPAIRED 215CC Trick Flow cylinder head GenX C
    For sale is (1) 215CC, CNC ported GenX Trick Flow cylinder head. It is a bare cylinder head that had the pushrod holes bored for a larger pushrod. Unfortunatly (2) of the pushrod holes were cut to deep and broke through the intake port. The heads have been repaired, pressure tested and flow tested. They still flow the factory cfm. The repair is only about a 1/4" on each port. As a matter of fact, I saw the port before it was repaired and it was basically a pin hole. The shop that repaired it is very reputable and guarantees it to function as it was originally intended to. This head is brand new except for the repairs done to it.
    If you are interested, I can PM you the serial# that is cast into every TFS to identify it and its production date.
    If you want a set of these heads, this is a good way to knock of a good chunk of change off of the final price. I gained 60 RWHP with just these heads using a stock cam!
    I am asking $550 O.B.O. + $15 shipping
    (Serious inquiries only. Please do not waste my time with LOW BALLING)
    If you are interested, PM me and I will send you back my cell#. I am tired of all of the PM's. I can give you all the info you need in 5 minutes on the phone instead of 20 PM's back a forth.
    [IMG][/IMG]
    I probably hate you bowtieguy02SS's Avatar
    Nov 2008
    Indianapolis
    Sunset Orange Metallic
    2002 SS
    warranty?
    doylestown, Pa
    17 (100%)
    SILVER
    2004 CTS-V
    Quote Originally Posted by bowtieguy02SS View Post
    warranty?
    There are no warrantys on cylinder heads, but I guarantee it will work or you get your money back. I have a high trader rating, never ripped anyone off and I intend to keep it that way.
    Nov 2008
    Indianapolis
    2002 SS
    what supporting equip. will i need? head bolts included, length of push rods? very interested..
    doylestown, Pa
    17 (100%)
    SILVER
    2004 CTS-V
    No, head bolts are not included. I would recommend ARP studs if it is FI but you can use stock replacements for NA.
    You will need a longer pushrod and they run about $110. I forget what length. I will look it up for you.
    Trick Flow recommends using a roller rocker since it has special valve guides.
    doylestown, Pa
    17 (100%)
    SILVER
    2004 CTS-V
    You will need a 7.5" pushrod. Stock pushrods are 7.3"
    Nov 2008
    Indianapolis
    2002 SS
    ok ty and you will stand by your product?
    doylestown, Pa
    17 (100%)
    SILVER
    2004 CTS-V
    Yes, I will stand by the product. If you put it on and there is some issue, I will refund your money provided that you ship the head back to me.
    Michigan
    2000 Camaro Z-28
    So this sale is only for 1 head and not 2?
    doylestown, Pa
    17 (100%)
    SILVER
    2004 CTS-V
    Quote Originally Posted by natzke4 View Post
    Yes, (1) head is for sale.
    doylestown, Pa
    17 (100%)
    SILVER
    2004 CTS-V
    Come on peeps, make me an offer. I need this gone.
    doylestown, Pa
    17 (100%)
    SILVER
    2004 CTS-V
    bump....
    doylestown, Pa
    17 (100%)
    SILVER
    2004 CTS-V
    New pics
    Here are some more pics as per request.
    I have numbered all of the intake ports in the following pics which help to describe the following:
    Below two pics are the repaired ports
    The rest of the pics show that none of the intake ports were touched and therefore needed NO repair
    I have numbered all of the pushrods holes in the following pics which help to describe the following:
    The following pic shows that #2 hole was machined and is now repaired.
    The following pic show that #4 hole was machined and now repaired.
    The rest of the pics show that non of the pushrod holes were touched and therefore needed NO repair
    doylestown, Pa
    17 (100%)
    SILVER
    2004 CTS-V
    SOLD!
    Member side2000's Avatar
    md
    2000 camaro ss
    nice. it was killin me to see ya struggle to sell that thing.
    doylestown, Pa
    17 (100%)
    SILVER
    2004 CTS-V
    Quote Originally Posted by side2000 View Post
    Thanks
  1. Trick Flow Cylinder Head Upgrade For 2 Valve 4.6L
    Last Post: 05-18-2010, 03:00 AM
  2. Trick Flow Cylinder Head Upgrade For 2 Valve 4.6L
    Last Post: 05-18-2010, 02:50 AM
  3. Trick Flow Cylinder Head Upgrade For 2 Valve 4.6L
    Last Post: 05-11-2010, 01:10 AM
  4. Trick Flow Cylinder Head Insight - CHP Insider
    Last Post: 08-21-2009, 10:00 PM
