    rice..a growing epidemic PAT-LS101's Avatar
    OREGON
    blue
    2002 camaro z28 a4
    got bad piston slap.. Which oil??
    Im using royal purple 10W30 right now.. what do u guys think is the "best" oil ?? I was going to try Mobil 1 30W??
    Bragg NC
    Met. Sunset Orange
    01 SS
    Why 10w 30? How many miles do you have on the car?
    J
    Arizona
    I run 10w-30 in both of our SS's. One has had piston slap forever and the other doesn't have the slightest hint of it.
    Luck of the draw I guess, but I can tell you I run the same oil in both so I'd venture to say the oil I'm running has nothing to do with it.
    I have heard of people switching from synthetic to regular dino oil (same weight) and the slap is less noticable. Not sure why, I've never tried it myself.
    OREGON
    blue
    2002 camaro z28 a4
    Yeah.. I have it pretty bad when it starts up sounds like its going to fall apart but goes away and running for a bit....
    Nov 2008
    harrisburg pa.
    02 vette vert
    i dont know if i buy that oil makes any diff in the piston slap. when i bought this car w/1111,000 it had it, changed oil w/10/30 dino, then couple hundred miles later w/5/30 castrol edge syn., and the noise never changed. its not a condition like noisy bearings or lifters at cold start where oil could make a difference imo. the type of condition that exists which causes the noise is totally different. the ambient temp does seem to play a part in the severity and duration of the piston noise though, which makes sense.
    Arizona
    Quote Originally Posted by dklowrider View Post
    Just stating what I've been told. Never tried switching myself since I have a pair of 4th gens and only one is doing it. Both use the same oil
    Just one of the evils of an LS motor. Pretty common actually.
    Arizona
    Quote Originally Posted by PAT-LS101 View Post
    Mine does it cold. After running for a few miles it goes away so I just don't worry about it.
    Now if it drops a piston skirt in the pan I might have to do something about it
    Honestly I just look at it as a reason to buy a crate motor in the future if it gets to that point.
    38 of 139 PontiacFan's Avatar
    Kearney, NE
    2001 Pontiac
    Search 'German Castrol'.
    People swear by it, reducing noise, ...
  1. Piston Slap?
    By 1999sscamaro in forum Internal Engine
    Last Post: 10-31-2025, 05:43 AM
  2. Piston Slap + Cam = ?
    By WS6ICK2K in forum Internal Engine
    Last Post: 05-05-2008, 07:14 PM
  3. Piston slap or not???
    By casperss in forum Internal Engine
    Last Post: 09-21-2007, 07:06 PM
  4. piston slap?
    By wicked illusions in forum Camaro / SS
    Last Post: 05-28-2006, 05:27 PM
  5. Piston Slap
    By CamaroSSx1999 in forum Internal Engine
    Last Post: 08-29-2005, 01:43 PM
