Thread: DRL problem
    Member transamdude99's Avatar
    East Wenatchee, Washington
    1999 Tran-Am WS7
    DRL problem
    so i have a problem thats starting to be a pain in my ass. the DRL on my passenger side doesnt stay on when i turn my headlights on. it will be on when im just using my running lights but as soon as the headlights pop up then it shuts off. and when i have the lights on and use my blinkers, it will flash like normal but then go back off when i turn the blinkers off.
    i changed the bulb and cleaned the connection out real good today but its still doing the same thing. any ideas?
    1999 Trans-Am
    Lid, Flowmaster cat-back, Eibach 1.25 Pro Kit, front and rear Eibach Sway bars, LS7 clutch C:\Users\Troy Boy\Pictures\Leonidas1.jpg
    1999 Tran-Am WS7
    any one??
    Houston, Texas
    2000 C5 Torch Red
    how corroded are the insides of your sockets. Mine would do something similar a while back. I did the cut free socket replacement and replaced all around bulbs with LED's and HD flasher. No problems since.
    If your socket is real bad, turn your headlights on to where the bulb quits working and then open the socket and wiggle the bulb in to see if it at any point lights up. That's how I determined my socket was getting a solid connection to the bulb.
    Member qwk93ta's Avatar
    Fairfield, Ohio
    00 WS6
    I did the same thing........
    Indianapolis
    2000 WS6 6spd Hooker LT
    Yeah, 99% it is a corroded socket. BTW, it is the parking light filament of the bulb that is not working due to a bad connection, if you look when you turn on the headlights you will see the one that is on is on at a lower intensity, not the DRL/turnsignal filament. Hope that doesn't confuse anyone!
    You can put your hazard flashers on with your headlights on, this is a quick easy way to walk around your car and check all lamps for proper operation, except BU and the third eye.
    1999 Tran-Am WS7
    is that a pretty easy fix? do you think i could get those parts at a local parts store?
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    Sockets are 3 wires. 8 bucks at autozone.
    Houston, Texas
    2000 C5 Torch Red
    Took no time at all to replace. I bought my sockets from O'reilly (can't remember part Number). Just ask them for the 3157 replacement socket, which will be very obvious as the same part your replacing.
    Get home and push in the two tabs on each side of your new socket. You should be able to gently pry the inside piece out. Then the three wires will simply slip out.
    For the old corroded ones, I wasn't too worried and ended up breaking them they were so brittle. Once you remove the center section the wires will slip right out of the socket. Pre number or take a pic and remember the color order.
    I then sanded the connectors until they were clean and then slipped them into the new socket and slid the center piece in locking the wires (might take a try or two).
    Installation of the socket into the housing may be tight your first time since it's a socket and gasket.
    Took about thirty min to do both. Any questions pm me.
    Auto Painter RyanJM's Avatar
    Houston, TX
    I finally had to change my passenger socket for problems with the blinker working. I swapped to LED's and disconnected those gay DRL's. All they do is burn out bulbs faster and heat up the lenses. I love my Trailblazer, it has a button you push 4 times AND drl's shut off. Although it I new how easy it was to disconnect the DRL's I would have done it earlier.
    1998 Trans Am 85k miles.
    02 Trailblazer -Sold
    09 Ram 1500 CC - Sold
    09 Cobalt SS/TC - Sold
  1. cluth problem??? transmission problem???? please HELP!!!
    By adamblake97 in forum Manual Transmission
    Last Post: 04-07-2014, 07:34 AM
  2. Obama's Woman Problem A Problem Of His Own Making
    By Ed Blown Vert in forum Political / Debate Forum
    Last Post: 01-14-2013, 02:50 PM
  3. Fuel Problem or Severe Engine Problem
    By pet_monk in forum General Help
    Last Post: 02-18-2008, 07:51 AM
  4. Electrical/charging problem problem
    By jchcomputers in forum General Help
    Last Post: 02-23-2007, 05:59 AM
  5. is it a clutch problem, or a tranny problem?
    By sgt0704 in forum Manual Transmission
    Last Post: 01-07-2007, 04:03 PM
